blitzkommando
- Oct 25, 2009
Alright, I decided to build a system in September around the i7 920. Part of my requirements was that I up the ante to 12GB of memory as I didn't want to downgrade to 6GB when I was coming from a Q6600 with 8GB, of which I found I would use upwards of 6GB.
In any event, I've had nothing but issues and have tried multiple sets of memory, motherboards, and even borrowed my uncle's 920 while I was building his machine. Long story short, I haven't figured out what settings, if any, will result in a stable system even at stock speeds and memory 'underclocked' to 1066MHz. I initially thought I was rid of issues when I got this UD4P to replace what turned out to be a faulty UD5 (all memory, in any memory socket, would instantly error out in Memtest).
As it turns out, I still get the beeping on every cold boot though it mysteriously disappears if I reset thereafter and do a warm boot. I've run Memtest with the 12GB Corsair XMS3 kit I got and it comes out error free. And, aside from very strange hanging issues, the system truly seemed stable. I had it running for over eight days without reset and finally restarted due to an update which required such. But, tonight, I encountered another bluescreen identical to the ones I got on the UD5 and EVGA X58 SLI LE when they were having stability issues. I've since further increased voltages and even turned off the CPU's turbo mode as well as Gigabyte's "turbo" feature for memory down to "standard" setting.
I guess what I'm asking is a few parts fold. Firstly, is this beeping, which was present with the UD5 along with error code 68 (both 920 CPUs mind, of which the other is working just fine with 6GB on my uncle's setup), normal for cold booting with 12GB of memory on Gigabyte boards? Secondly, are there people who have been successful in running 12GB, at stock settings preferably, and had the system stable with similar setups?
For reference, I am running the 920 at stock, the aforementioned Gigabyte UD4P, Corsair HX3X12G1600C9 memory at 1066MHz (533x2), two HD 4870 512MB, and an Antec TruePower 850.
I am so thoroughly frustrated that I am ready to sell the mess, aside from drives, and build a system with 8GB of RAM on a completely different platform as this is just plain ridiculous. I've been building my own systems since 2003 and have never had this much trouble getting a system stable, let alone at stock settings.
I apologize if this is in the wrong section, I'm still a bit new to the forums here but I figured you guys, if anyone, would have some ideas on this. It's quite frustrating to constantly be worrying about system crashes on my workstation/gaming computer.
