erek
- Dec 19, 2005
I grabbed one last year for $40ish Buy It Now. It had been sitting there because the seller listed it as a regular Rage. Got lucky.
Works great. One of the fans is loud - but I can't track down a part number for it to hunt for a replacement.
Ehhhh... No. Nobody is buying these for use.
They're famous for not being particularly well-running either. And the dual-GPU implementation here really hasn't been seen since and I'd be shocked if more than a few games even support it.
you should probably only emulate.
If you have a disdain for collectors then you should probably only emulate.
If you seek out these types of hardware but don't consider yourself to be collecting, then you're a fool.
Collectors, of all things, are also pretty much the only reason historic examples of products continue to exist in presentable, original working order.
Not really sure what the point of your post was.
