M a d c o w
- Feb 27, 2006
Hey Everyone ...
I finally got the chance to Install my X850 Crossfire VC w / X850XT Pci-e. Everything installed correctly. When it asked to restart the PC, so i did. After i turned off the PC it recognizes no signal to DVi-D. I have the Dell 2007WSP 20" widescreen. I did a little search in google from getting an updated driver for my LCD screen, downloaded the driver and then restarted again, still no no signal to dvi-d. I had to turn off and on the lcd in order to see the load up on windows. I had the ( DMS-59 ) Ati-y splitter connected correctly. What gives ? As my x850 crossfire vc connected into the primary pci-slot and the regulr x850 in the secondary. I disconnected the ( DMS-59 ) and connected only the dvi connected from the lcd and plugged it directly into the X850 crossfire's vc dvi connector. Turned on and off and gave me a signal and when my pc is turned off, it doesnt say the " no signal to dvi-d anymore ) Do i have a faulty ( DMS-59 - y-cable ) Suggestions ?
Thanks in advance
Thanks in advance
