almost every laptop has this atheros chip.
yet it runs like shit.
I have tried 2 different routers, updated to latest drivers.
I even checked driver settings to make sure it WASN'T locked in wifi B mode or something.
Doesn't matter if the router is 5 ft away or 30 ft away.
I tried the WRT54g, and another Westell broadcom G router.
but speed is capped at 1500 KB/s..... wifi B speed over the home network, when both pc's are using wireless. I can't transfer large files faster than that.
I have 2 laptops with this atheros chip, and you would think they would talk to each other better, and I would maybe see wifi G speed.
nope. only wifi B speed on a G router.
However, if one pc is on wired LAN, and the other is wireless, I can get over 3 MB/s between them. It's when they're both wireless that they are capped at wifi B speed.
Anyone have a solution ?
edit- maybe the router can't handle wireless to wireless transfers.
I enabled frame burst, and I was able to reach 1700 KB/s
