rampantandroid
- Jun 14, 2006
Hi all,
Just upgraded to a P8Z77-v Pro board from ASUS. I've got a 250GB Intel 510SSD as my boot drive, and I ran Crystalmark on it, with these results (I had closed CDM, and so re-ran with only 1 run, which produced numbers that are the same as running 5 times.):
The drive IS in AHCI mode, and IS plugged into the gray 6Gbps ports, so while the sequential read/writes seem in line with what I expect, the 4k numbers are WAY off. Am I missing something?
Here are the numbers from my old ASUS x58 sabertooth board, with the SSD running on the Intel 3Gbps controller:
Thanks!
Thanks!
