I have the older 6700k with the asus z170a board. I have an m.2 slot filled (i've tried enabled m2 express vs sata express in bios btw, but each time i restart it resets to sata express, unsure what the m2 mode even means, the onboard sata m2 nvme works fine).
So i have 2 nvmes, i put them in the supermicro unit, but each time no matter what slot i use, either the first or 2nd which should be 16x or 8x if both in use, it defaults i think to 4x, as the second drive doesnt show up.
I checked in the bios, there is no toggle to make it force 8x mode that i can see, though there is auto and gen1 through gen3, i have (pretty sure) tried gen 3 forcing with no luck.
Having the card in also causes weird bios loop issues if i try to tap del to enter the bios, it seems to almost reset the initial bios display of data where you tap delete, i had to go into windows and select uefi mode to get around it.
Since usually i cant even get to the bios once the card is in, i cant get in to look at the setting to see if its running at 4x mode or not (obviously is though).
Anyone else ran into this 8x issue with this board and found a fix?
Thanks in advance
Thanks in advance
