Asus X99 mobos and nothing but grief on POST with waterblocks.
Dajinn
So, I'm looking for some general thoughts here.
I've used 4 different CPUs historically and 2 different motherboards and I have the same problems across all of them.
When I try to boot, the POST will hang on bF 3 times and then shut down. Or, if I use the memtest button, I can get a post but when I apply memory XMP, the PC fails to POST again.
Both boards I've had this happen on, were Asus Rampage V Edition 10, and X99 Deluxe II which is my current board.
I've seen this issue on 5820k, 5930k, 5960x, and 6950x CPUs.
Before, I never had a problem using air cooler (Dark Rock Pro 3). The issue only cropped up when I started to use liquid coolers and water blocks. So, in order of when the issue started to first appear and what I've changed to since then, is NZXT X72, Corsair H150i, EK Supremacy EVO, and now Corsair XC9 block. And it was a problem with all of those.
The only 'solution' I've found is to back up on the screws until the PC can post normally and consistently on each boot with XMP applied. But this is not entirely scientific, as every time I've swapped CPUs to upgrade, it's a problem I have to waste time on because I am not entirely sure how far I need to back out the mounting. And I feel like I should be able to hand tighten each screw until it won't easily turn anymore and it still be considered 'in-spec', if that makes sense.
I've read before when I posted a similar thread, that this seems to be a 'common' problem (though I've never before read about it else where) with X99 socket on some boards (Asus in particular maybe?) due to un-even mounting pressure, however, I've never had a problem until I started using these blocks and frankly it p*sses me off every time I have to deal with it.
I was curious if anyone's had similar experiences and I also want to know if there is any reason to think that switching to a different manufacturer's X99 motherboard would help at all.
drutman
Funny my PC will not boot either if I try any XMP OC, I have the MSI Krait X99 mobo with a 5820K.
Evga x99 classified with 6850 and corsair 16 gb ddr4 3200 and gskill 32gb ddr4 3200. Ek supremacy evo- hand tightened. Never tried another cooler. Runs fine at xmp with corsair or gskill 2x16gb ddr4 3200. Anything beyond 3200 results in crash or bios reloads failsafe settings. Cant run anything higher than 3200 despite voltage, timings or speed changes. Xmp or manually input makes no difference.
If i keep it at ddr4 3200 it runs problem free. No matter the timings or voltage. 1 bump past 3200 it crashes.
Any speeds below ddr4 3200 runs fine.
Dullard
I never had any luck with any memory OC on my Asus RVE. In fact I never got the memory to run at its rated speed, much less XMP. I finally settled on running 3000 rated RAM at 2666 and have been stable ever since. X299 was much, much kinder to me in regards to memory than X99 was.
kirbyrj
From what you describe, it sounds like you'd have the same issue with any X99 board since the problem comes from the mounting pressure of your block.
