Hi guys
I have bought the Zalman Fatal1ty FC-ZV9, but unfortunatly the computer store has not delivered it so far. Now i can't wait any longer because i already missed the deadline for fixing that problem, and my client is crazy about that. It's for charity
Now i'm thinking of another GPU cooler the zeroTherm GX815.
http://www.zerotherm.net/eng/product/GX815.asp
And now my question is, would it fit on my X800xt - PE. Zerotherm does not say a thing about it, except that the ATI x1300 and x1600 should be compatible. And if you check the Zalman website:
http://www.zalman.co.kr/eng/product/view.asp?idx=215&code=013
you'll see that Zalmann says the Mounting holes for x1300 and x1600 is the same as for the x800. And i have checked the distance between the 2 mounting holes and the are 55mm.
What do you think, does it fit?
Thanks
Thanks
