D
Deleted member 72990
Guest
I'm having a hard time picking between these two motherboards.
I currently have a Sabertooth motherboard, so I was naturally leaning towards the TUF version, but I don't really like the new aesthetic that much, and I really hate that there is a fan on the motherboard that you can't take off - seems kind of gimmicky and those little motherboard fans always get whinny and die. However, since i cram a full SLI ATX system into a small HTPC case, I do like the armor on the board because it prevents cables and cooling hoses from abrading on the circuits on the board. Also I upgrade motherboards about every 5 years so I do like the robustness.
I think the Strix board looks really nice but doesn't have thermal armor, but also doesn't have that fan. Cooling might actually work better for me with this board since my fans will blow directly down on the board.
From a capability standpoint they seem similar and cost about the same.
Which do you think I should get? I plan on running 4000 MHz memory and overclocking the snot out of a 7800x.
Here's a pic of my current system internals to get an idea for how I need to fit stuff in there:
