asus x299 gaming with non qvl trident royal 3200
OpenLooper
Hey guys,
I was wondering if you think trident z royals 3200 will work with the x299 asus gaming mobo.
On gskill they only have the 3000mhz listed for working with x299.
The motherboard supports speeds well above 3200mhz.
Do you think the 3200's will work even though they arent spec'd for the mobo specifically?
lopoetve
Intel has always seemed pretty tolerant to me. I don’t think my 3600 is rated for my Z490, but it works fine
Shadowarez
iv tested a kit of 32gb 2x16gb gskill 4000mhz on multiple x299 cpus, and boards, asus sage,asus apex, work flawlessly,
OpenLooper
Thanks a lot guys! this gave me a bit of confidence when putting everything together.
EVERYTHING WORKED and ram is running at 3200mhz!
I guess I was just worried because I had absolutely NO luck with that same ram on x99.
OpenLooper
annnnd heres a pic
Shadowarez
i just got 8x16gb of this ram for my TR build when they drop the 5000x TR want me that 128gb+ low CL high speed ram.
Shadowarez
for these i thought i got lucky cl 16 3800mhz i have a kit of cl 14 3600 as well but only 32gb 2x16gb sticks,
