ASUS Vega 64 STRIX Crashing
Hey All, I have Vega 64 Asus Strix (ROG-STRIX-RXVEGA64-O8G-GAMING) and I'm struggling with unstabilized, after 1-2 hours of gaming the computer collapse (shut down) and reboot immediately I can't really get solved this issue no matter what I tried.
my system spec -
z390 designare gigabyte
4x16 ram corsair lpx
i9 9900k
Asus vega 64
hx1000i
3xhdd
2xm.2
corsair commander + 6 fans
Noctua dh CPU cooler
- Mobo Bios latest - F9b (also happened with F7) tried default settings and my Hackintosh version bios, no difference.
- AMD Latest driver 20.5.1 (also happened with the ASUS officially driver from their website and the AMD stable version 20.4.2)
- Windows 10 20H1 version
- Power connected with 2 different cables to PSU
- I set my PSU to a multi-rail mode in iCUE software, also tired with single rail mode, no difference.
- tried 2 sticks of ram, swap them, 1 stick, no difference.
- I did MemTest86, everything fine.
- tried different profiles on ASUS GPU Tweaks, also tried to change the bios from the card dual bios option, no difference.
- tried to update the firmware from ASUS website, no difference.
- tried to update the firmware from https://www.techpowerup.com/vgabios/ , again, no difference.
- temperatures are fine, around 70-80 Celsius
really don't know what to do or try, Asus support told that they can't do anything, and I can send the card to them, but I must to use this card for my working OSX machine, so I want to try to point on the problem.
I want to try to replace the thermal pad and change the thermal paste to try again and check if there are any temp issues, like in this post
please help! :)
noko
Underclock the GPU and GPU memory and see if that makes a difference or just set the Power Limit to like -50% then work your way up if the problem stops.
  1. Probably a good idea to re paste, since the temperature sensor is registering one part of the GPU, dried up paste can have uneven heat transfer so another part of the GPU could be much hotter than normal
  2. Underclocking or lowering the Power Limit will reduce the heat load on the GPU, which will also reduce the heat load on other parts of the computer, all this will tell you if it is heat/power related to something
What makes you think it is the GPU?
You can pull the GPU and re seat it, other option is try the other PCIe slot for testing purposes. Another graphics card available to try?
What power supply do you have, how old, how many watts? Does the fan speed up when under load on the power supply? Keep it single rail, no reason I know of going dual rail.
  1. As a note, I have a Seasonic 850w power supply on a 6700K plus 2x 1080Ti setup which now when gaming in SLI and both GPU's are working hard will do this as well, after about 1 year of mining 24/7 the Power Supply appears to have gotten weak. You could reduce the power of the GPU and then the problem goes away thinking it is the GPU when actually it is a weak power supply
  2. If you have anything shorting, USB device, motherboard, GPU, card etc. most power supplies will automatically shutdown -> So your power supply could be protecting against a short or low ground
    1. Heat on a component, motherboard itself warped and heat causing a short is not out of the whelm of possibilities
    2. Take everything out of the computer, put it on a box and test using minimal cards, hookups etc.
    3. Any extra power supply cables possibly grounding out? Look for odd things even something shorting out pins on the motherboard, blow out the computer with air, flip it upside down etc. - even shake it and listen for anything loose
  3. Blow out the power supply, clean any filters, (most of my cases have filters for the power supply, one of them I have to actually take the power supply out to clean it! errrr)
  4. Try a different power supply if you have one, currently new ones are very hard to find and/or very expensive
Anyways you have to isolate the actual cause
Reactions: N4CR
Furious_Styles
You should try to isolate the problem. Run a CPU bench like P95/OCCT and see if it crashes and check temps. Then load up the GPU with a bench from unigen (heaven/superposition) and do the same with temps. You can use MSI afterburner for this. I highly recommend uninstalling all of the asus software.
Thanks for the reply!
noko great advice and ill try to under-clocking the GPU and see how it will react.
I did mostly all of them, I don't have a spare power supply to check, but I try to disconnect and connected everything again and try to see if I can point on something . this machine is one year old. Seldom gaming, only in the last four months I start to use the GPU more, so everything is still "fresh".
My first thought was that the power supply might be causing some issue. Still, some people told me that the behaviour of my machine that crashed and rebooted immediately does not sound like PSU.. but I tried to check all the wires and people that build the same specs as I did, and I can't find any problem. I don't know how I can measure the PSU without external hardware...
I'll try to make the CPU bench and see what's going on, about the GPU bench; I can't understand what do you mean? To make benchmark and change the values on the MSI burner or in the and tune section ? or just to check temp or stability ? in general, when I'm making the bench test for the GPU its pass every time.
blackmomba
I had your card and also had problems but mine was a driver issue
What happens when the machine crashes ? How many monitors ?
I had your card and also had problems, but mine was a driver issue.
What happens when the machine crashes? How many monitors?
Hey! Thanks for the comment.
Interesting, so how you fixed your problem ? after install a specific driver or tuning settings?
When it happens, the computer completely shut down, and imidiatlyy run again, like a restart. I'm using one monitor 3440x1440, and lately, I add a small monitor. But this issue happened before I add the small monitor.
PontiacGTX
Try an older driver (read the unsolved problems for the verison you are using and the one you plan to install)version if not RMA it...
It's an excellent idea. I tried that with the official driver form ASUS website for specific that card, and I remembered that was sable, but it crashed too, I can try to check another old version, do you remember which one was worked for you?
DrDoU
green screen crash or black screen crash and then reboot. after 20H1 update were drivers,video, reinstalled? Have you tried just the driver only leaving out all of the other features? maybe overlay problems. have you updated to the latest mb chip set drivers? Trying to think of something other posters have left out.
ManofGod
my system spec -
i9 9900k
Asus vega 64
hx1000i
3xhdd
2xm.2
please help! :)
Well, I own the exact same card, an RMA replacement that I bought from someone on here last September, and I have had zero issues with it. My guess is because it already has the proper thermal pads already installed. Therefore, I would do that, if you have had the card for a few years.
PontiacGTX
I am using 20.3.1
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-20-3-1
Radeon RX Vega series graphics products may experience a system crash or TDR when playing games with Instant Replay enabled. A workaround for users experiencing these issues is to disable Instant Replay.
I dont have this issue but you can install this driver and try this, if it doesnt work try undervolting it and reduce a bit the clock speed it could be a problem with voltages so voltages might be low for load or you might be experiencing overheating (use hwinfo to read gpu,hbm and vrm temperature)
if it doesnt work register your card for warranty and start the process for RMA (I dont know how is done the process with ASUS)
N4CR
PSU most likely if it's VGA related. Try using MSI Kombustor at native resolution or something that loads GPU up, it's how it diagnosed my PSU/V64 setup issues. Watch the power lights on side of the card.
V64 crashes are most likley when you don't have FPS limiter e.g. in menus and the fps shoots to 1000 and power spikes - power spikes/transients are most of the issue powering a V64. Undervolting and limiting FPS will make a big difference if that is your issue and you are waiting on a new PSU.
Hey again, well I did the thermal pad and paste change, and under-clock the GPU from the Asus GPU tweak II to this settings -
GPU clock (Mhz) - 1400
GPU Voltage (mV) -1100
Memory Clock (MHz) - 1900
Memory Voltage (mV) - 1100
Fan Speed - Default
Power target (%) - 90
GPU Temp Target (C) - 78
external fan speed - default
the default settings is -
Gpu clock (Mhz) - 1630
Gpu Voltage (mV) -1200
Fan Speed - Default
Power target (%) - 100
I can play a bit longer but I for crash-reboot a few times since then ... I'm lost for more ideas
N4CR
Voltage is really high for GPU core speed. Do you have another GPU to test?
Also try hbm underclock
bluestang
Undervolt that Vega! Default volts are way too high.
GPU no more than 1050mv. I'm between 1000 and 1050 depending on what I'm using the GPU for.
HBM can be set at 1000mv and still hit stock MHz.
And get rid of ASUS GPU Tweak and use AfterBurner or just use Glabal Wattman in Radeon Settings. I just use Wattman as AfterBurner doesn't let me do/control some of the things I want to.
I have the Sapphire Nitro+ Vega 64 and my settings in Global Wattman:
Performance / Watt Profile set to Custom
GPU Frequency (MHz) set to Dymanic and at 1632 in State 7
Voltage Control (mv) set to Manual and 1000mV
Memory Frequency (MHz) set to Dymanic and at 1000 in State 3
Fan Speed RPM) set to Manual and 1750 min / 2750 Target
Temperature (C) Control set to Manual and 80 Max / 75 Target
Power Limit set to 20%
Setting to Dynamic allows the Card to self regulate based on temps and load. You will most likely end up with higher MHz too than with stock volts as stock volts cause high HBM temps and high GPU Hot Spot temps.
ThreeDee
what exactly are you running for a PSU? .. I had similar issues with totally different hardware an it was my PSU that was failing. Swapped it out and back to being a stable machine again.
PontiacGTX
if undervolt and underclocking doesn't work then RMA the card if possible if not time to upgrade getting a RX 5700(XT)
