Sprayingmango
- Jan 20, 2012
So here is a good one for all of you...
I noticed that whichever card I have on the bottom of my SLI stack behaves in a weird manner.
The fans turn on / off / on / off every few seconds and the card makes a "grinding" sound. I put it in quotes because it's not physically grinding anything, but rather its just the voltage I assume. You know the sound an old mechanical hard drive used to make when the head would search? That's what I mean.
I swapped the bottom card to the top and it happens no matter which card is there. If you look at the pic I posted from GPU Tweak II, you can see that blue line with the peaks. That is the bottom card. It happens even when I put the cards into "Zero DB mode" which is even MORE confusing!!
Anyone have a clue what's going on??
