deadman_uk
- Jun 30, 2003
I live in the UK. I use an OpenReach modem with an ASUS RT-N66U router for my fibre optic 80/20 broadband. My ISP (Plusnet) provides internet through PPPoE in which I have to enter in a username and password to access the internet. I use a static IP address which I paid for. A number of devices share this connection, including 2 PCs, and 2 smartphones. I am happy with my ASUS RT-N66U router’s performance; however, there is one problem that I would like to get sorted. If I get a power cut, or if I power off and on the router (or modem), I have to wait much longer than I would like for the router to find a WAN connection.
As a test, I powered the router off, then back on again, visited my router page of http://192.168.1.1 and sat watching the Internet Status section of the Network Map. With a stopwatch going in the background, I would time how long it takes for the ‘Internet Status’ to change from disconnected to connected. I did this 4 times (with one time also rebooting the modem as well). I discovered that I am waiting between 5 – 7 minutes for a WAN connection to be established.
This is an expensive router and I don’t find this acceptable. I have a number of cheaper routers here, and when there is loss of power from the router, modem (or both), I only have to wait 2 minutes maximum to have a WAN connection established. Why is the RT-N66U so slow? Does this have something to do with my static IP? Currently it's set to PPPoE on the router page, which is how I always set it up.
Thanks
Thanks
