*derp*
My restriction is that I need to have the 3.5" cage
I mentioned that on and off in my replies.
But at any rate, my order was cancelled twice (eBay seller douchery) so I won't be on it for a bit~
Okay then add cryorig C1 to nh-c14 and possibly big shuriken 2
I can double check my c14 if ya want , but see your pm I was talkin bout the new one is the one which may not fit [10mm past board edge is what determining factor in your 3.5 cage issue arising, Or not]
EDIT: Apparently there may be an issue with sfx psu and c14 when fan mounted in bottom position.. . N1 case
-The shuriken 2 would only be 70mm tall or so with a 25mm normal 120mm fan though so idk sorry just tryin help here
