Tri SLI = IRQ #24, 30 & 32
X-Fi Titanim in the upper pci-ex1 slot IRQ #16
No popping or crackling
Sounds like you need to select "no plug & play OS" in the bios & reload windows so that the bios can delegate IRQ's.
Unfortunately the only way to reset the IRQ's after selecting "no plug & play OS" is to reload a fresh copy of the OS afterwards.
Hope that helped.
Quick question for you that are familiar with this board.
There is a 7th SATA port which is not on the ICH10R in the lower right below the 6 SATA outputs. I have an eSATA port on the front of my case which I will connect to it. There is also an eSATA output on the back of the board which is the one I will be using. I am assuming this is the same port and that I can only use one e SATA drive at a time, either the front one connected to the post on the lower Rt or the rear. Is this correct?
Also, there is a 1394 output on the back as well as a 1394 set of pins in the lower left of the board. Are they two 1394 ports and can both be used or only one at a time.
I am wiring and if there is no sense in connecting the two sets of outputs on the board (the eSATA and the 1394) then I will not bother running cables to the front of my case for them.
The 2 eSata ports you refer to are both active; I've used them both.
Same goes for the 1394 ports, both active & tested.
If I remember correctly, you can even set up raid 0 on the Jmicron eSata ports on post boot. You'll have to install the Jmicron raid driver to that though.
Great, thank you both! I am all built now except for the CPU and Memory. As I cannot fire it up yet I have really taken my time with the wiring, this is the neatest build I have ever done. I think that as soon as my memory comes in I just may buy an i7 920 and start with that CPU and upgrade later.
I am building a new rig using the Rampage II. So far I have the following.
Case Tt Armor+
Mobo Rampage II Ex
PSU Corsair HX1000W
GPU BFG GTX 285 OCXE
Boot and OS drive 2 300 Gb V-Raptors (RAID-0)
Storage drive 1 Tb WD RE3
Optical drives 2 ASUS SATA DVD RW
Floppy and card reader
CPU cooling Zalman CNPS9900
Fan controller NZXT
Sound Card Internal supplied software X-Fi for now
The key missing componnents are:
*The CPU. I have been waiting for the i7975 to become available but the prices on the 920 are getting so low and I am tired of waiting so I am thinking of starting with it and seeing how far I can OC it on air and then upgrade to a 975 later.
*The Memory, I am waiting for the Dominator GT to be available again. I am going with the lower latency instead of the higher speed.
Any comments on my choices so far and any and all advide will be apriceated.
I am so glad I found this thread as I am far from an OCing expert and it looks like there are a number of you who have experience with this board.
I have a question about the case dimensions needed for this board to do 3 way sli. My case is a Silverstone Tj09 with seven slots. Will I be able to fit 3 gtx cards in there?
If this question has already been answered I appologize...
Thanks.
This mobo is wider by one inch over standard ATX mobo. Measuring from the back mounting rail straight across to the very tip of the HD/front mounting housing, if the clearance is 11 inches or better then you are fine. If not, you have a problem (especially with long GTX285/295 cards).
Was wondering about the slots... I have seven in the back. I think that with my case 3 way sli will not work though the motherboard will probably have no issues fitting...
Thanks.
For Baer: Just delivered from Newegg and it's Rev. 2.01G
ButchB
My R2E has just arrived Rev. 2.01G and it won't fit my Silverstone FT01 B/W case.
BUT "Mister Dremel" will make it fit oh so snug in its new home.
Going to Home Depot for a fresh supply of cutting disks. (and a beer)
Butch
Thanks, that pisses me off as I just got mine two weeks ago and it is already one rev behind.
I wonder if that may also be a difference with the P6T Deluxw Version II??
That is the public stance but I believe that there were other tweaks.
BTW, I was able to get one of the new version R-II Ex Bds
I just confirmed that the original release is indeed 2.01G, so I'm not sure where you get the information that it is the new revision.
No way no how will a GTX295 fit(in my case) for tri-sli. This case has 7 slots.( Silverstone FT01) I hope that helps.
ButchB
...Ohhh look my Asus cold boots fine now what should I do with this gigabyte EX58-Extreme, I should hunt down a customer for it ASAP.
Would love to, but curretly I live in KSA and shipping from there will cost an arm and a leg!
I'm looking for a local buyer.
