ASUS Prime X570-Pro Aura Sync issues
nguyen704
Does anyone have this board? If so, were you able to get Aura Sync to work? I can't get it to work for the life of me. I tried installing the latest version and I always get 'Aura Service is unavailable' error message. No workarounds have worked for me. I tried using Armoury Crate, but it doesn't detect my motherboard. I am completely stuck.
Specs:
3900X
32GB Crucial Ballistix 3200Mhz
1TB Inland NVME
Forgot to mention I have iCUE installed to control my keyboard.
nguyen704
I think the motherboard I got is bad. The motherboard VGA and Boot led now stays constantly on and there is no display. Aura sync issues and now this? I question the quality of this motherboard.
M76
For what it's worth I installed Aura sync on my X570-F, but I uninstalled it in 2 minutes. It worked. But I don't care about RGB lighting. I just wanted to turn it off completely but I'm not going to run a huge bloated service just to get that achieved.
kirbyrj
Can't you do that from the bios?
nguyen704
Holy crap... I finally got Aura Sync to work on this blasted motherboard.
  1. I uninstalled the previous Aura Sync software
  2. Deleted all related folders in Program Files
  3. Run CCleaner to clean registry
  4. Restarted PC
  5. Download Aura Sync 1.07.71 and extract it to the Download folder
  6. Open Powershell as admin
  7. Run the following script in Powershell (This installs all the .exes in aac folder)
    Set-ExecutionPolicy -ExecutionPolicy Unrestricted
    Get-ChildItem "$HOME\Downloads\Lighting_Control_1.07.71\LightingService\aac" -Filter *.exe |
    Foreach-Object {
    $params = "/uninstall", "/passive", "/norestart"
    & $_.FullName $params
  8. Run AuraServiceSetup.exe (if installed correctly, the RGB lights should turn off for a brief second and turn back on)
  9. Run AsusSetup.exe (if installed correctly, the RGB lights should turn off for a brief second and turn back on)
  10. Restart PC
It baffles me that I had to take these steps to get Aura Sync to work. I assume running AsusSetup.exe first wasn't enough to install all necessary files for the service to work correctly on this motherboard. Hopefully this works for you.
Dark12
  4. Restarted PC
  10. Restart PC
I am going to try this tonight.
I've been pulling my hair out over this. Lol
Thanks for posting your fix!
Dark12
There is an xml setting file left behind after uninstallation in LightService folder. Deleting that and reinstalling fixed it for me.
Finallllly
kamikazi
I have the Asus Crosshair VIII X570 and I did have an issue with Aura Sync. One reinstall did the trick though. I got rid of Armoury Crate as it conflicted with Corsair iCue. If you have iCue running, you do have to download a patch from Corsair for everything to work.
kirbyrj
I had this issue the other day...
From what I can tell, you don't actually use the Aura Sync program anymore. Uninstall it.
Download Armory Crate and use the Aura Sync program from within that program and then it works fine again. Not sure if this is related to the more recent LED firmware update on the X570-Pro board.
mcoleksajr
I'm so fed up with the Aura Sync and now this Armoury Crate software. Asus never seems to get any of their software right. AI Suite has been notoriously horrible for as long as I can remember also. I can live without the AI Suite, but my rig has all kinds of addressable rgb lighting in it. Everything worked great until Armoury Crate was released. Aura Sync started giving errors that the lighting service wasn't running even though it showed up in the task manager. Then I noticed the new AC software and it worked for about a week and stopped detecting my Strix X470-F a couple of days ago. I even went through the effort of doing a clean install of Win 10 today and still the same thing. I think I'm done with Asus after this. Most of the software issues can be worked around or just not used at all, but when a custom build requires software to work it's quite frustrating. I'm thinking of going with the Gigabyte X570 Aorus Master for my next mobo. I'm just kind of waiting for Black Friday and Cyber Monday to roll around. It's been a long run for me with Asus. I've been building PCs for 25+ years now and have always sworn by their motherboards. It's just sad that it's over software. This is the 2nd mobo with Aura Sync and the same issues. The 1st was a Strix B350 when Ryzen first came out. Anyway, that's enough of my venting. Hopefully someone figures out a consistent fix, since it's apparent that Asus can't get it right from the developer's end.
Dan_D
Extremely [H]
I've run into the problem you are talking about once on the test bench. Aside from that, it's always worked well for me. I have it running on my current system and its fine.
mcoleksajr
For the most part I could get the different versions of Aura Sync working. It usually just took making sure that the old version was completely uninstalled before installing the new. I knew how to fix it so it wasn't a big deal. Armoury Crate was also working great up until it updated a couple of days ago. This time it's really weird. My addressable 5v header that I have running 2 SATA 5v powered hubs works perfectly. It's the 12v headers stuck on green and the I/O cover doesn't do anything at all. Without any form of Asus lighting software installed, it does the usual rainbow cycle on all the lighting so I know that the LED strips connected to the 12v headers and I/O cover lights are working. When I installed the Armoury Crate software after the clean installation of Win 10 the addressable lighting works and the 12v headers stick on green and no I/O cover. My Strix X470 does not show up in Armoury Crate at all. I completely uninstalled AC with Revo Uninstaller Pro and went digging for left over files and folders even. When I installed 2 different versions of Aura Sync, 1.07.71 and 1.06.17, it would give me the lighting service was not running error and Aura Sync wouldn't run at all. I'm just really frustrated with it right now. I'll mess with it again tomorrow... Maybe.
mcoleksajr
I thought I'd at least follow up after everyone putting up with my rant. I was about to give up completely after I don't even know how many attempts at trying different things. I even went back to the October build of Win 10 before 1909 was installed with a clean installation and turning off Windows Update. Still the same bs. I don't know what made me decide to install iCue for my Vengeance RGB Pro lighting BEFORE using Revo Uninstaller Pro to get rid of Armoury Crate again, but I'm glad I did. When the drivers for the RAM installed and the little Windows notification played for new hardware being detected all of a sudden my lighting that's run by Aura Sync changed behavior also. I opened Armoury Crate and everything is detected again and it all works perfectly. I don't know what combination of stuff finally worked, but ultimately the installation of iCue fixed it. I think it has something to do with the November update to Windows also, but whatever. I'll leave Windows Update turned off and be done with it.
myVick23
I'm having the same stuck on green issues:( put a lot of work into my rgb setup and it lasted 1 day after finishing. Connections are good, 5v addressable work great. Both 12v headers acting the same green replaces red when calibrated green and blue are swapped. Went through the whole uninstall process. :spitoutdummy: Pretty much-done everything you did still stuck.Thinking of replacing my mobo (asus prime x570 pro). any help would be greatly appreciated!
AMD Ryzen 3700
Prime X570 Pro
Aorus Geforce rtx 2070 super
Starfalcon
RGB software just sucks, it would be great if you could just do it in hardware. I keep reseting mine to just red, and next reboot back to rainbow puke.
kamikazi
I'm using iCue with a Corsair Commander Pro on my Asus X570 Hero VIII. The only thing I'm using the mobo to control is the on board LEDS and my G.Skill Trident Z RAM. I actually have it turned off because the white color on the RAM doesn't match anything else. I have 6 LL120S fans, an EK waterblock with dRGB, and the Lian Li Distro-Plate for the PC-O11 Dynamic. I bought some adapters from ebay for the waterblock and Distro Plate that allow them to plug into the corsair lightning node pro, which plugs into the Commander Pro.
The Asus software flat out sucks and takes a lot of refreshing to get working. At first only one RAM stick would respond. I found a reddit post which said:
"Uninstall Aura. Redownload it. On the .7z file, right click it and go to properties. At the bottom, you'll see "This file came from another computer and might be blocked to help protect this computer"
Check the "unblock" box next to it. Click 'apply' then hit okay. Now extract the files and install. I have a Z370-E and Trident 16gb 3200 RAM and that's what solved it for me."
It worked for me, too. Just be sure you have 7-zip on your computer to do it.
Reddit post referenced above
scoobert
I have a strix -e and have zero issues with sync.
Are you running other software on top of it like the nzxt stuff or corsair stuff? I have a friend who was having issues with sync on his strrix-f but only after he installed the nzxt software. Once we got all of that out of the registry it started working right again.
mcoleksajr
I got an alert for a new post to this thread this morning so I thought I'd follow up. I've updated my hardware since I posted last. After all the problems with the Strix X470-F and Armoury Crate I even went to a Gigabyte Aorus X570 Master to give it a shot. For some reason it did not like my R7 3700X at all. It wouldn't even post. After some research, I found that I wasn't the only one having the problem with a Gigabyte board and specifically the R7 3700X. Anyway, a RMA and back to Asus with a ROG X570 Crosshair VIII Hero. My scenario has this added now: I also purchased 2 sets of the Corsair LL series fans in white with the announcement at CES of iCue and Aura Sync actually working together and being designed to do so now. Out of the box the only thing I did was to NOT install Armoury Crate when prompted at first boot. This prompt can be turned off in BIOS as well. I already knew about this step due to researching the shit out of it before committing to the LL fans. First, I downloaded the Aura Sync software from here https://www.asus.com/campaign/aura/us/download.php, make sure it's version 1.07.79. Then made sure I had the latest iCue software from here https://www.corsair.com/us/en/downloads. Once downloaded, and before unzipping the Aura file, I did all the click properties and check unblock song and dance on both files. Unzip and install Aura Sync first with admin permissions. This needs to be installed to set up the 5v and 12v motherboard headers with the correct amount of LEDs and to "calibrate" the colors. At this point my motherboard lighting was working correctly on it's own. I restarted the computer and even tried different sound sources to make sure the sound effects were working right. So far, life is good! I then installed the iCue software with admin permission. Everything went as hoped and my motherboard even immediately showed up in the iCue software. Now one thing to mention that this was all done from a clean installation of Windows, but it's been about 3 months now, and even with updates to Windows and iCue everything is still working. There is a small glitch with the motherboard lighting on occasion, but as soon as I manually re-sync the Aura software it's fine again. Aura works better now, with the iCue software running, than it did when it was all by itself. I used to have to go into task manager and completely shut down everything that had to do with Aura Sync, or restart my computer, to get it working again. I haven't had to do that in the last 3 months at least. Everything seems to be working in harmony now and I haven't had to do anything to force it to stay that way. I am currently running the same Aura Sync version 1.07.79 and iCue version 3.28.70, iCue has updated a couple of time since the initial installation. Windows has done it's usual updates and hasn't caused any issues either. I can't speak to Armoury Crate working or not. Since I'm running the iCue software with the LL fans I never even bothered with trying and at this point it works the way it's supposed to so why try to fix something that isn't broken.
kamikazi
I can see the motherboard lighting in iCue as well with my Hero VIII. I didn't take all the steps you did though. It just started working with an update of iCue. I usually have the motherboard LED stuff off to be honest.
mcoleksajr
I really don't either. It's more of a "showing off" thing when clients come to my place to drop off their computers to work on. Between the custom cooling and lighting it's a pretty big "WOW" factor for the average PC user. 😎
nguyen704
This actually worked for me after doing a fresh install of Windows 10. Installing Aura Sync before iCue did the trick. No more "Aura Service is unavailable" error!
