I do not like glossy finish and would much rather matte. Any idea when asus one is coming out?
Wow that is a long ways away...there is nothing else?!
It will be out in August
not october or december![]()
Read'em and weep kid:
Now all you'll have to do now is find out what "Q4" means.
Are Asus from Norway? Is this a reliable source? Could this simply be regional availability in Norway rather than the rest of world? Also, he does say they don't have exact info, so he seems to be guessing and erring on the side of caution with that guess, hence the word "probably". It also does seem rather long to wait to release it, as the panel is available so they just need to build the thing. The only reason I can think for that kind of delay would be a licensing issue where in which Acer have exclusivity for a year or something with the XB270HU. I can't believe Asus don't want to release this sooner rather than later.
Why the hell is the PG279Q taking so long to get to market when ASUS obviously has stockpiles of the same panel for the MG279Q?
Geez, I may just break down and get an Acer XB270HU. This G-Sync monitor money is burning a damn hole in my pocket!
Stories? Do you think it's one big conspiracy against Acer? You do realise there are batches and batches of these monitors that are basically junk. You just need to read the multitude of threads on virtually every PC related forum to see this. I don't dispute it's a fine performing monitor when you get a good example, but many people have gone through 3-4 replacements all with faults. None of this changes the fact it looks cheap though, with that chunky bezel and glossy piano black base. But if you don't care for such things and can find a good one, go nuts.don't believe the negative stories around the net about the Acer, just go for it.
Do we know if this is going to have an A-TW polarizer or not?
I really don't understand why some companies produce IPS panels without them, since that is the main reason anyone would buy IPS. (viewing angle)
Looks is clearly a preference thing but I really don't think it looks bad at all. The Acer XG looks a lot uglier. Yes it does NOT look as good as the swift but it's passable imo. I personally don't think it's worth waiting for months all because of a thicker bezel and glossy finish when you could be enjoying a really great gaming experience right now because the 2 monitors are practically identical.
Does anyone know the reason for this?Unfortunately, I don't really think that would happen since A-TW polarizers seem to be limited to only a few top end non-gaming IPS displays now.
I don't suppose there's any possibility of that being an issue with a pre-release sample which won't affect the final product, since it was months ago?
I am quite certain, as with so much in life, that it is about money at the end of the day. I don't know what it would cost Asus to add a polarizer (assuming there are no technical limitations), but whatever it is I am sure they have come to the conclusion they can sell just as many monitors without it and therefore maximise their profits. They are a business at the end of the day. Unfortunately, the vast majority of people who buy monitors for gaming (which is the target market for this monitor) don't know what the hell an AT-W polarizer is, even though they would absolutely benefit from it. You can bet Asus know this when it comes to costing this monitor for production. Making something the best at any cost is not their remit... making as much profit with as little expenditure as possible is. The way of the world...Does anyone know the reason for this?
It's not like this is going to be a cheap display - sure it's not in the price range of an Eizo or NEC professional monitor, but it's still a premium-priced display.
Isn't viewing angle the main reason that people sacrifice things like contrast ratio and response times to go with an IPS panel rather than TN or VA?
Without an A-TW polarizer you lose most of the viewing angle benefits.
That picture being linked is backlight bleed, not IPS glow. The AT-W polarizer would do nothing for that situation. It's a poor, grainy photo with brightness on the monitor absurdly cranked I'm sure. Now, that isn't to say I would be surprised if the production models do suffer from backlight bleed...
At any rate, the AT-W polarizer film does not eliminate glow, but rather diminish it. It is a filter (kind of like AG coating) applied to combat the observable white glow, but can introduce green or magenta/purple hues in it's place.
Just ordered a Acer XB270HU for 598.00 no tax special
sorry asus but from the rumor i have heard you are using the same panel as the MG279q and your ULMB is not as good as the Acer XB270HU
Since the ROG PB279q wont be out for another 2 months and for 800.00
big no no
no, it isn't. the picture shows mostly IPS glow with some backlight bleed on the right. the quality of the photo is irrelevant. yes it exaggerates it, but that's not the point, the point is that there is obviously no A-TW polarizer being used, otherwise it wouldn't look like that.
and yes, an A-TW polarizer DOES eliminate glow.
Please learn how to read and do your research. ACER THEMSELVES have confirmed bad batches of these screens, and there are HUNDREDS of reports of people getting faulty ones that clearly shouldn't have even left the factory. Of course it doesn't mean EVERY monitor is faulty... but an unacceptable percentage are.1 bad monitor is 1 thousand bad monitors on the net, please learn how to use internet.
If the asus comes out with all the same specs shouldn't it be priced similarly to the Acer? I to am waiting on the asus bc I want ti get what's best, I currently don't even own a monitor but running my pc to a 55 inch Sony waiting on the right one. Also debating on whether the step up to 27 from 24 is worth it
Isn't that mainly a problem for GB-R backlit displays using an A-TW Polarizer, rather than W-LED backlit displays?At any rate, the AT-W polarizer film does not eliminate glow, but rather diminish it. It is a filter (kind of like AG coating) applied to combat the observable white glow, but can introduce green or magenta/purple hues in it's place.
http://www.prad.de/new/monitore/test/2015/test-nec-pa322uhd-teil7.html said:
http://www.prad.de/new/monitore/test/2014/test-eizo-cg277-teil7.html said:
http://www.prad.de/new/monitore/test/2015/test-asus-pb279q-teil6.html said:
FreeSync is not G-Sync.its already been proven that the MG279Q has more lag than the acer due to the extra HDMI port. If you want the best gaming monitor get the acer or just want something cool to look at get the asus
the stand and monitor bezel is alot nicer.
Wide-Gamut W-LED A-TW (NEC PA322UHD)
Wide-Gamut GB-R LED A-TW (Eizo CG277)
sRGB W-LED without A-TW (ASUS PB279Q)
MG279Q latency results will almost certainly differ from the PG279Q.
