Doug, for what it's worth, I'm experiencing the same issues as you... it's driving me nuts. :-/ Same rig, slightly different memory, same cooler, slightly smaller PSU
The bottom X-shaped backplate is the default backplate installed with the mobo, I just used that. The square one is the X-socket backplate.
Is your DVD on Intel port 6 - last SATA 3G on lowest/ bottom?
Do you have AHCI set in Intel SATA?
Yes
Do you have hot plug enabled in bios for 2 Intel SATA 6G ports?
Left at default settings
Did you turn off all other SATA controllers in bios during install?
Again, let at whatever is default so probably not.
Did you partition with Win 7 install by using custom install?
Yes; I always remove all/any existing partitions and let Windows create its own system partitions.
How did you setup partitions?
Removed all partitions in Custom install, highlighted drive for OS and clicked 'Next' to begin install.
Did you remember to format the actual partitions and not the 100mb reserved?
Again, I let Windows set all this up. I don't set up anything partition-wise during the install.
Another update: I called ASUS, and they said they won't have any in stock for at least 15 days, and that I should call back 15 days from now and ask again. You've got to be kidding me... I'm pissed off to the extreme right now.
