cantankerous
- Nov 15, 2006
Hello and thanks for taking the time to read the following.
I am looking into building a new system as soon as the B3 revision of boards begin to ship. I am looking into the Asus P8P67 standard model. I must get this particular model due to the expansion slot arrangement. It is exactly how I need it and the Pro/Deluxe variants offer a much different slot arrangement which is not suitable for my needs unfortunately.
I am needing to know 2 things in particular about this motherboard and how it will interact with other parts. I will be using the 2600k CPU.
Cooling:
I was thinking of getting the Noctua NH-D14. I take it this will be suitable for an overclocked 2600k? An important thing however, with the rather large size of this HSF, does it intrude at all on the ram slots of the motherboard? I need to be sure all 4 slots will be easily accessible to add/remove ram at will. Is this possible or not? Does the heatsink or fan lay on top of the slots in any way?
Ram:
http://www.gskill.com/products.php?index=357
I need to know how well this ram plays with this particular board. Is it 100% and recommended or no? I am undecided if I should go with 8GB, or go all out with 16GB. Opinions? My question above about the NH-D14 covering the ram slots was due to my possibly occupying all 4 slots with a 4GB DIMM in each to obtain the 16GB. Will the heatspreader of this ram fit under the NH-D14 with ease if the HSF does overlay the ram slots?
The rest of my system will be recycled from my current sig, case, power supply, hard/optical drives, fans, sound card, video card etc.
Knowing all this information, can anyone for see a problem with the older parts of my sig being used in this new build? Are my chosen ram and HSF sufficient or are there other recommendations? Again, I must use the standard P8P67 however.
I do appreciate any comments, suggestions or confirmation that can be given regarding my build.
Cooling:
Ram:
