I am looking at the paper version of the documentation Second Edition Octobe 2010:they are in the manual, right?
But I have not been able to find an ASL Status Code Section in the documentation?reserver for ASL (see ASL Status Codes section below
I do have 2 x Samsung HD103 SJ 1000GB drives. CrystalDiskInfo indicates a Firmware revision of 1AJ10001....
Conclusion:
Intel Southbridge will not detect, or do so intermittently with certain brand OLDER HDD firmware that do not have specific coding to allow Intel Port 1 and 2 to allow it as a SATA 6 drive or is buggy by itself. This may be why some guys have no probs - newly purchased new model drives, and some do - old drives. There ARE drives SATA that are specifically specced as SATA 6 interface EVEN THO they only do 143MB/s transfer and 246 Burst
You could try 5-6 jumper to make 3Gbs set max on later drives (WDC)
If you want trouble free Intel SATA 6Gb useage, make sure the drive specs say SATA6 interface. Or at least until they fix this issue. Then again, even these drives may need firmware update. At the very least either Intel or ASUS should give Samsung a call and ask them what kinda magic is in their firmware fix
http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=308&ref=dynamitedata.com
Just experienced SLEEP ISSUES as well.
After no issues at all for 1 week...last 2 days comp won't wake from sleep. Restart button does nothing. Have to do a cold power reset.
Any ideas why this just started? Any ideas what triggers it? Solutions? Suggestions?
My specs:
ASUS P67 Deluxe
2600k
Evga GTX460 FTW
8GB Gskill 1600 CL8 RAM (2x4GB)
Update -
We setup five stations to try to replicate this problem and so far all machines have over 100 hours on them without a problem, this includes multiple sleep routines, benchmarks, network transfers, etc before just letting them sit and run. We have not rebooted the stations yet.
So I am gathering complete system configurations from affected users now and will have an udpate early next week.
I'm currently running the latest NIC drivers from Intel but just experienced a random freeze earlier today. Although, it did not seem to take down my entire network this time.Has anyone tried the latest chipset/NIC drivers from Intel (not the older drivers from Asus)?
As far as the chipset drivers, I have not bothered with them yet.
For reference, I was having the same "sleep" issues w/ my new Asus Sabertooth P67 / i7-2600k build (and actually with a M4A89GTD PRO/USB3 / 1090T build, but that's even further off topic lol and ended in RMA for refund after two boards). Issue was remedied by changing Windows power settings to "never sleep" (still left in balanced mode). Its been nearly a week since the box crashed.
I'm very skeptical about Asus bios quality right now. So many threads in the Asus support forums regarding these types of issues on current gen mobos - AMD & Intel chipset alike.
Turbo enabled, but not overclocked.Do you have your processor OC'd?
Its weird that it happens like that. A few days (even a week) can go by with no issues and then all of a sudden, freeze left and right. Atleast, that's what has happened with me.Well My pos asus p8p67 is starting to freeze in less than 3 minute's. ( it worked for 5 days perfect) now i cant even get into bio's without rebooting. Im soo pissed, I knew I shouldve not baught new tech.
SSD's have the trim issue
If trim is not working, or not working optimumally, things can get messed up to the point that data corruption happens or data loss.
Its like a garbage disposal that is never emptied an eventually clogs up.
This is not fixed by a format or fresh install.
The OCZ forum has lots of good info on this
I wouldnt even THINK about running an SSD without the Intel RST 10.1.0.1008 or higher. This is the first RST that does trim correctly. The dif is truly amazing
the second issue is that the Intel P67 chipset seems to be very picky about firmware on HDD especially certain SSD's and F3's.
So to rule these out, I would just unplug the SSD and try a spindle HDD.
Where did you hear TRIM has any impact on data corruption, because that isn't true. All it does if affect long-term speed degradation issues. And a secure erase will repair any slowdowns caused by not using TRIM. And I don't believe RST is required for TRIM, it is natively supported in Win 7 (at least) by the MSAHCI driver.
I've already opened an RMA with NewEgg for my P8 Pro.... I'm going to be switching to the Gigabyte UD7 B3 when it hits the Egg's site. I'm done with Asus, too much of a pain.
