MooCow
- Apr 13, 2000
Ok, so basically I have the so called great P5ne board paired with a Q6600 G0 stepping. I unlink memory and CPU and up the CPU from 1066 to 1200MHz FSB. RAM is still @ 667MHz. CPU voltage is 1.43 and it won't POST anything past 1200MHz. This is only 2.7GHz on the CPU. What gives? I also upped RAM volts to 2.1, northbridge to 1.57v. What else do I need to do? I believe I once tried 1.45v on the CPU and it still couldn't POST past 1200Mhz fsb.
I am running a stock cooler, but even if it can't cool it well enough, it should still POST, right?
