MassiveOverkill
- Jul 8, 2005
I replaced mine, so I'll get you the info when I get home tonight.
This board is awesome, indeed. My Q6600 is cruising along cool and comfortable at 3GHz (stock heatsink) and I feel like there is plenty of headroom left for the future. Also got an Asus 8800GT that surprised me with a non-reference heatsink design that also kicks ass. System is super quiet and running stable on my ancient 350 watt power supply (yeah, I know, weak-sauce!) in a Q-Pack. I believe this was the easiest new system install & overclock I've ever done.
Today i´m going to test 4x1GB Kingston HyperX pc9600 on this board...
Hi Tremeloes
I wonder if it would be possible for you to run 3DMark2001 with the onboard graphics of the Asus P5E-VM HDMI.
If its IDE, and the only device, make sure its set to Primary.Guys... noob question for you...
Any ideas why it's not detecting my dvd drive?
Just did the Vdroop mod. Looks good: Bios 1,5 V -> Idle 1,48 V ->Load 1,47 V.
Raised my max. stable FSB with 1.5V from 370 to 380. And it looks like the restart bug is gone.
@ Allsop
you did the Vdroop Mod, too. Do you have the restart bug?
That message about the CPU fan, when booting, is annoying. I don't have a CPU fan to connect to it. Both of my front 120mm fans are connected to the available 3-pin fan headers. Is there anything useful (besides a fan) I can connect to that 4-pin PWM fan header that will stop this message from appearing?
Is there an option in the BIOS somewhere to disable this message?
Sure your RAM is all the way in? What about the 4-pin power connector on the motherboard?
How many ports does you video card have? Have you tried plugging the monitor into each of the card's ports? Have you tried powering up with just the bare minimum (1 stick of RAM, processor) and plugging the monitor into the motherboard's onboard video?
You're using the stock 380 watt power supply? Does the CPU fan even spin up? Are you sure you have the power button panel connector properly connected to the header? Manually use a small screwdriver to jump the power pins on the motherboard to make sure your power switch isn't malfunctioning or hooked up wrong.
