Looking great Lars_L.
We have almost the same configuration.
I'm using the E8400 with the same cooler, and Crucial Ballistix PC8500 RAM.
Currently my CPU is running 3.6 GHz, and is under load not over 36-37°C
It's a great system. To cool the NZXT Rouge and the Thermalright, I've found some 120 mm from Nanoxia.
BTW. what is you're oppinion on the NZXT Rouge so far?
any clues why i cant go up to FSB 500 with my Nvidia 9800GX2 gfx card installed?
with my Nvidia 6800 it works perfect.
could it be that i need more volt to the North bridge with the 9800GX2?
(see previous post about my system setup )
Edit: here are some pics with both the noctua and 9800gx2 cards for those who wonder if it fits
http://dwd.pir8.info/pics/DSC_1282.jpg
http://dwd.pir8.info/pics/DSC_1618.jpg
http://dwd.pir8.info/pics/DSC_1624.jpg
http://dwd.pir8.info/pics/DSC_1625.jpg
http://dwd.pir8.info/pics/DSC_1626.jpg
http://dwd.pir8.info/pics/DSC_1633.jpg
http://dwd.pir8.info/pics/DSC_1630.jpg
are at least four of your SATA ports usable with a 9800 GX2?
Here's my spec (in sig too)
asus p5e-vm hdmi
xeon e3110 @ 3.4ghz
patriot 2gb*2 5-5-5-15 @ 2.10v 780mhz
MSI 512mb 9600gt (stock)
2x Maxtor 500gb (raid 1)
Vista x64
almost all boards that i know of only clock well when no more than 2 sticks are used.
Can anyone else comment if you have tried to connect to a gigabit switch using the atheros on board lan? If it works what driver version/settings are you using? No matter the driver version I have tried, if I set it to 1000 or auto it can't connect, have to manually set it to 100.
Thanks!
i am connected to a gig switch.. no problem
it is set to Auto/Auto and negotiate to 1Gbt
Driver Provider: Atheros
Driver Date: 2007-12-20
Driver Version: 2.3.7.9
Digital signer: Microsoft Windows Hardware Compatibility Publisher
