Asus P5B-E, Kingston HyperX 750MHz, e6300.. Help me OC
Troxx
I can use FSB 320, but there is problems getting higher..
Basically I don't really know for sure what the settings in BIOS should be.
OC of Ram only should tell me what to expect from ram... The Kingston 2GB HyperX PC6000 should run at 750Mhz or FSB:RAM = 1:1 = 375MHz but that seems impossible. Ive seen OC of this ram from 850 - 950MHz.
So images of Bios settings similar to my setup is what im hoping for.
OC of C2D 6300 should be easyer, but a nice guide for P5B-E would be great.
This is taken from somewhere else, but I changed it a little to reflect the options on the P5B-E.
My settings:
AI Tuning: Manual
CPU Freq: 417
DRAM Freq: DDR2-834
PCI Express: 100
PCI Clock Synch: 33.33Mhz
Spread Spectrum: Disabled
Memory Voltage: 2.1V
CPU Vcore voltage: 1.3875V
FSB Termination: Auto
My settings:
Modify Ratio: Disabled
C1E Support: Disabled
Max CPUID: Disabled
Vanderpool: Enabled
CPU TM: Enabled
Execute Disable: Enabled
PECI: I can't remember
My settings:
CAS Latency: 4
RAS TO CAS: 4
RAS Precharge 4
RAS ACtivate: 12
Write Recovery: 6
TRFC: 35
TRRD: 10
Write to read: 10
Read to precharge: 10
Write to precharge: 10
Static Read Control: Disable
Thanks a lot :)
I'm now running 3080MHz with 440HMz FSB... I'd like to thighten the ram later.. :)
Bios settings are much like yours:
PS: Printed on CPU: L629B162
Advanced Settings
AI Tuning: Manual
DRAM Frequency: 880
PCI-E Frequency: 100
PCI Clock Synchronization Mode: lock this in at 33.33MHz
Memory Voltage: 2.0
CPU VCore Voltage: 1.4
FSB Termination Voltage 1.450
* NB VCore: 1.7
* SB Vcore (SATA, PCIE): 1.60
* ICH Chipset Voltage: 1.215
CPU Configuration:
Modify Ration Support: Enabled
Ratio CMOS Setting: 7
Max CPUID Value Limit: Disabled
Vanderpool: Disabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
PECI: Disabled
Intel Speed Step tech. : Disabled
Northbridge Chipset Config
Memory Remap: Disabled
Dram Timing by SPD: Disabled
latency: 5
RAS to CAS delay: 6
precharge: 6
activate to precharge: 15
write recovery: 6
DRAM TRFC: 42
TRRD: 10
Write to read: 10
If your P5B-E is showing this values
* NB VCore: 1.7
it is likely a newer revision, possibly 1.02g. :eek:
Can you confirm that the highest memory voltage available is 2.4v ?
Thanks
Diote
My card is 1.01 :-( Highest Memory volt is 2.1
The values you mention is not on my card.. i kept them in my doc for reference... They are marked with * ... I should have commented it I guess.
I run FSB at 420MHz now. Orthos (stess test) tells me there is an error, and it's brobably the ram. But i've heard people running this ram at 1000+ MHz (500x2)..
Temp is now 51...idle.
