PinPickles
- Jun 13, 2019
Hey guys. I have a an ASUS P10S-M WS ( https://www.asus.com/us/Motherboards/P10S-M-WS/) on the way. It has an 8 pin connection for CPU power.
The modular PSU I plan on using it with has 8 pin connectors in the front for CPU/PCI-E, but only came with these weird cables that go from 8 pin (with two empty pins) to 6+2 pin. The "8" (really 6) pin in labeled PSU and the 6+2 is labeled PCI-E.
Are those the ones I should use? Or do I need to get a different cable?
Thanks.
Thanks.
