All,
I have been searching to see if there was a way to disable the CFG lock on the Asus MIVE. I have seen some posts for BIOS descriptions stating that the CFG lock can be disabled to increase superPI scores.
I am not able to find this option, does anyone know where it is... or if it actually exists in the GUI?
Thanks!
Adam
[EDIT] The CFG lock setting is under the DRAM timing config page. Thank you Mason!
Thanks!
Adam
