asus maximus formula and asus p5e
Link
MF and P5E share the same pcb and components, exept P5E is missing some sensors.
Bios is also different, but you can force-flash MF into P5E no problem.
Hypernova
The extra BIOS options, extra fan headers and sensors. So if you don't need the fan controls you can just get the P5E and flash it with MF bios. It will complain that some temp sensors are funky but you can disable the warnings and enjoy the more advanced OC tweaking features. tRD setting for example is not available in the P5E bios but is in the MF bios.
