I was looking over MicroCenter's current sale pricing on nVidia GPUs, and saw some rather surprisingly low pricing on some GTX760 based cards; the even bigger shock was the lowest-priced of the lot was the ASUS GTX760 DirectCU II - http://www.microcenter.com/product/...erclocked_2048MB_GDDR5_PCIe_30_x16_Video_Card
Yes; I noticed that this card is also an [H] Silver winner - that is why I was shocked to see it priced that low.
The question is should I wait until after upgrading the CPU and motherboard to replace the 550Ti with this card, or can I do the upgrade now (though I expect some hobblage)?
Unlike most GTX 700-series GPUs (and even most GTX760s - stock or otherwise), I only need a single 8-pin GPU power plug; I have one 6-pin (which my current card is using), and one 6+2-pin that is not in use. (Basically, so much for power issues with a single GPU.) Further, unlike my current GPU, the HDMI port is full-size - not something that requires an adapter/dongle. It has greater memory bandwidth (256-bit vs. 192-bit) and twice the onboard memory (2048 MB vs. 1024 MB). The ultimate question is, how much would a Q6600 (my current CPU) hobble it with non-next-gen games (Crysis 2, NFS Most Wanted, etc.)
