ASUS GTX 670 or ASUS HD7970
Discussion in 'Video Cards' started by rem451, Oct 3, 2012.
  1. rem451
    rem451 n00b
    31
    May 11, 2012
    i want the most 1st)quiet and 2nd)better vga, which of 2?
    What about asus gtx 680?
    thanks
  2. CleanSlate
    CleanSlate [H]ardness Supreme
    5,129
    Mar 28, 2003
    Loaded question.
    What are your other specs, what are you using it for, and are you stretching your budget too much or are these well within your budget?
  3. ReaperTech
    ReaperTech Limp Gawd
    237
    Sep 27, 2012
    depends on the GPU and the cooler,
    7970 or 670 the 7970 will clock further and offer better performance example the Powercolor Vortex II 7970 is $440 its pre clocked at 1100 MHz which makes it faster than reference GTX 680s and its damn quiet.
    that said if they are Direct Cu II models then the GTX 680 is better because ASUS locked the voltage on their 7970s to only be unlocked when using ROG connect or w.e which is a giant pain,
    Powercolor and Sapphire are the better options for the 7970s in that regard.
  4. rampantandroid
    rampantandroid [H]ard|Gawd
    1,962
    Jun 14, 2006
    I have the Direct CU2 670 and love it - insanely quiet. Also, having physx for stuff like Borderlands is awesome. If you plan to play games like Borderlands or Batman, go with nvidia.
    Wanna back that up? A review of the powercolor shows it holding even with the reference 680, not beating. Tweaktown as the source.
  5. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    12,885
    Jun 13, 2003
    This. Need a whole lot more information to make a decision between two very similarly performing cards.
