Wait for fully clocked 590 with some non-reference cooling and most importantly 3rd 8 pin PEG connector for additional power.
C'mon MSI give it some TwinFrozrIII treatment!
(Emphasis mine)The Review said:Worth noting is that all of the GTX 590 cards brought to market will be built by NVIDIA, so you will not be seeing any "special sauce" in these cards. ASUS and EVGA will be exclusively handling sales of the GTX 590 in North America.
The true potential of this card won't be known until review sites examine it's overclocking potential. It's quite obvious that the only thing differentiating the 590 from 580 SLI is clock speeds, so if the 590 can reach 580 clocks the 6990 will not be as good. The 6900 tends to gain ~10% of its stock performance after overclocking, the 590, I predict will gain more. In other words, my point is, the 6990 is better than the 590 when both are stock, the 590 will probably be better than the 6990 when both are overclocked (I mean that on-average).
One thing I want to mention, is that you guys neglected to mention the memory bus on the 590. It doesn't just have the shading potential of 580 SLI with 512 shaders, it has a 384-bit bus, it is 580 SLI, except with a muzzle .
Zarathustra[H];1037020984 said:Yeah, I based that comment off of Anands review.
The [H] uses triple head (which is appropriate for these cards) so the results Are going to be different, that being said this doesn't explain the full difference...
Derek Wilson, Anandtech 01/28/08: I'll still stand by the fact that it is not necessary to look at gameplay situations in order to build an accurate picture of the relative performance of a graphics card.
Although, I believe overclocking to extreme levels will help the card, in a review like this using surround resolutions I do not believe the Vram on the GTX 590 will allow it to push ahead. Perhaps at 2560x1600 with moderate IQ or below but not in surround. Also it's 384bit bux x 2.
I don't think VRAM will be a limitation at 57 x 12. 580 SLI has enough VRAM to be the fastest setup available, and it has 1.5GB. I think raw performance is the limitation, and the 590 will gain a lot.
I find more value in "Apples to Apples" than "highest playable"
I understand the "real world gaming results" just fine. The problem is what you think is highest playable settings, and what I think are highest playable settings are very subjective. Given the choice of a higher res vs. enabling AA, I will always go with the higher res. AA is the very last thing I would turn on in any game if i found I had the overhead.
Either way, you cover both bases, so great job.
really though how many [H] readers game at 5760x1200. i think you need to include what he majority of your readers probably game at realistically 1920x1080 , 1900x1200
but good review. it hit right where i expected it to..
not even closeI wonder if the 28nm GPUs will hit by summer?
Zarathustra[H];1037021226 said:Not necessary.
If it provides acceptable franerates at 5760x1200 then you know it will work well at lower resolutions.
Traditional bar charts are kind of dumb really. Who cares if a new video card gets 160fps at 1080p vs the 120fps of the older card. They are both playable and there won't be a notable difference.
not true becasue this is showing the 6990 is the winner per kyle at those resolutions. but if you go to the other review sites. the 590 is winning in some of the lower resolutions. so again depends on the game you play. LIke WOW which alot of people play the 590 owns the 6990.
Zarathustra[H];1037021329 said:Then your gripe really is with the games used for testing, not with the test methodology
Zarathustra[H];1037021344 said:As long as your minframerate is above 60, it doest matter if you get a bagillion FPS or if you get 70 FPS. It's still a tie. It can play the game.
I find it a bit ironic that you find 2 video card setups "idiotic" but you have multiple RAID cards in one box.Yes I do need SLI on one card. With couple RAID cards it is the only option really. And because I find whole 2/3/4 SLI[CF] with 2-3-4 cards idiotic.
Honestly I'm not surprised at all with reference GTX590, I was expecting that from the start. It was obvious that both chips and mem must be seriously under clocked to keep the power drain within some acceptable levels (<-375W). Wait for fully clocked 590 with some non-reference cooling and most importantly 3rd 8 pin PEG connector for additional power.
He said minimum frame rate.no cause 60fps can be 30fps real quick.
Uh... 6990 gets roughly 80-90fps at 1680, 1920, and 2560 (all at 8xAA). GTX590 gets between 105-110 at those same resolutions. Yea, 590 'owns' 6990 there, but what's the difference? You're maxing out settings either way, and both are far above 60fps.
Also, those numbers aren't changing much between the different resolutions. Seems like something else is holding things back.
So, yea, ok, 590 is faster at the lower resolutions, but both are already so fast it doesn't really matter.
dont know what review you looked at but it was 121 to 151fps. and thos FPS can dip real low when raiding.
http://www.techpowerup.com/reviews/ASUS/GeForce_GTX_590/18.html
And - quite frankly - as log as you are getting min framerates in the 30-60fps range it doesn't matter which card "wins". That's why tests at lower resolutions than the max playable are a waste of time.
This is not an FPS competition, it's a "can you play a game at these settings or not" competition.
Otherwise you've got the lame reviews where they claim one card is better than another because it got 270fps in Quake 3 instead of 250fps...
Just went off the first thing that came up in google. Interesting that these guys are getting significantly lower FPS.
guys guys guys
Tri-sli GTX 590
finally we can play crysis
OMG here we go with how does it do at 1680x1050 or 1920x1080. If you SPENT $700 on a video card you DAMN well have spent 2x that on your monitor. IF your still playing on somthing you got from walmart Get your ass off the [H] forums.
Can this fit into a netbook? I play competitive Angry Birds, and any dip below 500 FPS could cause me to lose a crucial point.
