BurntToast
- Jun 14, 2003
Strange effects. We've got to try something else, then.
Did you do some tests like window movement tests at the desktop?
E.g. dragging a window around? Did you try PixPerAn, to see how the motion looked?
Did you try the full version of the registry tweak from the other forum, and see if that worked better?
My windows login screen looked like this.
I suppose I can try the full registry setting. But I'd rather not rely on a hack. Having it be a pull down option in the Nvidia control panel is much more appealing.
If you miss not having a CRT, the VG278H or VG278HE will be the closest thing you can get if you wish to relive the experience. I game in 2d and the difference between a IPS or other TN panel is very obvious. If you can get lightboost to work on top of it, then win win.So you would recommend its worth buying a lightboost 2.0 monitor for?
