elvn
- May 5, 2006
What is the equivalent size vs distance perspective unit ratio wise?
That is, a 27" at 1.5 to 2 feet at a desk... how many feet back would a 32inch or 40 inch display have to be to fill the same portion of your viewing perspective? Paint an imaginary grid on the far wall for example. Where would the two monitors cover the same number of squares to your viewpoint, compared to the 27inch at 1.5 to 2 Feet? (or vice versa moving the 27" compared to your prefered monitor size + viewing distance).
I'd prefer a wider aspect monitor due to the way HOR+ is used and game's zoom out and HUD limitations, or I'd prefer this monitor to otherwise be 40" so I could run a 21:9 resolution or other windowed resolution 1:1 at 108.8 ppi . However, to be fair, at a desk viewing a 27" 16:9 game world at 1.5 to 2' is as large to your perspective as a larger monitor further away.
In comparing this to other larger monitors some prefer, keep in mind none of them will be 1000nit FALD which is a huge difference. Hopefully that tech will be available in more full featured gaming monitors (low 8nput lag, low response time + modern gaming overdrive, g-sync/variable hz, high hz) in the future though.
