Some lightbleed at 100% brightness
Got it mounted on my stand. Don't like the led lightening that is standard fare for a lot of gaming equipment so the stand it came with had to go.
I like the screen, it is lacking in viewing angle compared to my old Dell U2412M IPS, Colours might be a tad less vibrant. Hard to say really..
Had some lightbleed, but nothing that is noticable in daily use or even in dark moviescenes.
How it looks mounted.
It is very sleek and good looking with a slim bezel. I tried Blacklight and CSGO at around 120FPS with Gsync enabled and there was a noticable
difference in how smooth the everything felt. The biggest reason I bought this screen was so I would stop having to deal with either vsync lag or tearing.
And now I don't have to make that decicion and that makes me a happy gamer.
I thought the stand LED can be turned off?
Is the monitor really splotchy like that or is that just the camera playing tricks? Because that looks awful. Not what I would expect for $800.
Nice one for posting photos. I share the same sentiment with regards to coloured lights and the shite they put on gaming gear.
Anyway which do you prefer in CS, ULMB or G-Sync?
I don't know, but if B&H have them available for shipping on the 18th I'm going to have to call around to make sure I don't miss the possible availability at other retailers on that date. I can't take time off just to fish for a monitor...
When is this going to be available at the other etailers like Amazon, NewEgg, TigerDirect etc.?
To go Surround or not to go Surround? That is the question.... hmm...
I thought I read somewhere in the thread that G-Sync doesn't yet support surround, might want to verify that before laying out the cash for 3 of these.
It does but you need tri SLI. For that res and hz, probably gonna need minimum 3xGTX780's
Nice looking setup Locrin. Looks like the perfect place for a PC.
Can I ask you to try something for me? I want to know how uniform brightness and color is when viewing the monitor directly from center. The top 1/3rd of my VG248QE is darker and it drives me crazy.
Here is an easy test. Sit with eyes in the middle of the screen and no tilt on the screen. Pick a thread here on Hardforum, just use this thread. Pick a message within the thread and scroll it to the bottom of your screen. Now scroll that message to the top of the screen. Do this a few times while paying close attention to the brightness and color of the message. Can you tell me if there is any shift in brightness or color from top to bottom of the screen?
Thanks a bunch!
IPS isn't everything sold my IPS cause the blacks were too dark in some games where it made it a POS monitor.
Currently G-sync is not supported in a surround setup. Likely an issue of bandwidth with the card and some driver work on Nvidia's side. Probably not a feature you'll see for a while.
http://www.newegg.com/Product/Produ...4236205&cm_re=asus_ips-_-24-236-205-_-Product
21.5 ASUS sold it for 55.00 at a Rummage sale
I use TN until they get the blacks right it would work as performed If you turn the brightness way the hell up then you would just get blasted by LED lights.
It could be the 6bit 8 bit panel thing or whatever but I had a few people with similar problems on message board there was on guy on Maximum PC did agree with me.
What brightness setting is that though? My current display also looks like that at maximum brightness but it's acceptable at the correct brightness value anyway. Nearly all 120Hz+ displays tend to have lightbleed at higher brightness values since they tend to be fairly bright and the "accurate" calibrated brightness setting for the monitors is often in the range as low as 25 - 38 even which will have significantly less backlight bleed visible than like 75(+) it's usually default set to (way too bright anyway).
What level of light was in the room when you took that picture? The wall behind your monitor looks way brighter than the bleed, were all the lights off? I ask because cameras tend to dramatically exaggerate the brightness of blacks/bleed in a monitor when it's much more subtle to the naked eye.
It's a big blob of black crush is what it looks like. Clouding. This is something you might expect from a TN with higher than normal contrast.
However, that is a severe anomaly not found on the review samples and I would reroll another unit unless you hated something else about it. To my eye the actual bleed around the edges is fairly minimal for a modern Lightboost display. Thanks for posting the photo.
Thanks for the details. I agree, the edges aren't too bad but that non-uniform blob is a problem on a display of this caliber.Picture was taken with lights off with some daylight filtering trough my curtains in the adjacent room. It's kinda hard to explain what level of brightness the room was at. But yes it is a lot more visible when viewed trough a camera. It is still easily noticeable in a bright room at 25-50% brightness to the naked eye whenever the screen turns dark.
Not sure if one has been linked yet but massdrop is getting close to the needed votes. They were able to get a pretty sweet discount on the LG ultrawide. Lets see if they can get us a sweet deal on the swift!
https://www.massdrop.com/vote/1440p-gsync-gaming-monitor?s=rog%20swift
Just checking but make sure you're setting your displays refresh rate to match the content you're playing back (24hz with Anime I'm guessing?)
You may also want to try using a media player such as MPC-HC where you can utilize a plugin such as MADVR(http://forum.doom9.org/showthread.php?t=146228) which has settings that will further eliminate any judder you experience when playing back media with variable refresh rates.
If you need help setting up see here: http://www.ibisgaming.com/content.php/155-MPC-HC-Ultimate-Setup-Guide
Not sure if Newegg is getting ready or it is something else but now when I search for "PG278Q" it is randomly not giving me the 0 results found message anymore. It does not show up in the list but it as if the website is detecting that the page exists in their database but is flagged not to show or something. Could be a general error though.
