Hey guys, i just splurged and purchased the Asus A8V. I swapped out my old mobo, and put in the A8V and my brand new 3500. The changeover went fine, but the problems started as soon as i turned it on (as they usually do ). It shows the little booting graphic, then scans for drives. This is where it says "Hardware Initiate Failed, Check Cables(or something to that effect)" Then, under this it says "Bios Not Installed" which confuses me to death because i am able to get into the bios. It says press <g> to continue. So i press 'g' and it scans for something else now, i assume the other sata chip, it then finds my raptor(system disk), then after that screen it asks which flavor of windows i want to load, i select the correct one and press enter, then it sits at a blank screen for a few seconds, then reboots! i never see the windows loading screen or anything. So i go into the bios and look around, i have both onboard sata chips enabled (i have 1 raptor (true sata), and 2 ide drives using sata convertors, and 1 ide drive using ide ). In the bios it does not see any sata drives, it only sees my one ide drive, and so apparently it's trying to boot from it, which won't work b/c there is no OS on it. This brings me to my next dilemma, where can i see what sata drives it detects?! The only drives i've ever seen it list in bios is the 1 ide drive, which does me no good. Luckily i'm at work so i don't have the temptation to smash the thing to bits, but this is driving me nuts. Does anybody have any suggestions? I plan on updating the bios during lunch today, i would've done it last night, but i let my friend borrow my floppy drive and without being able to boot to windows, i have to have it. So my friend is bringing it over during lunch, and i'm going to attempt to update the bios, but i'm not sure that will even help. I really hope this is just a setting in the bios that i'm missing, and not a physical problem
Thanks for your time
