RHollister said:People getting BSOD i would suggest pulling out only the required hardware. Video card memory CPU see if you still get it. SEcondly I would go into the BIOS and disable all onboard stuff see if maybe you are getting some conflicts. Thirdly what is the timings on your memory? if you set the timings to tight windows will either blue screen or just reboot. If you have cheaper value ram you need to loosen those to 2.5 Cas and maybe 2T. Dont get frustrated, its just a matter of trial and error, try something to see if it stops the errors if it does then you can work from there. I have built two completely stable machines around this board, the reviews out there are very flattering for this board. Dont give up hope, once you get it to work it will be worth it. Is anyone overclocking here? RAID can be a tricky beast to get going try not using the RAID array. Get a different HD install windows if it works fine then you know its the RAID. There are the things that I do when I am troubleshooting a computer. Dont be to affraid to mess around with things, there isnt a whole lot that will hurt it and even less that will hurt you.
RHollister,
Thanks for the words of encouragement, helps alot. Any advice for those not getting BSODs but having POST problems and random freezes ?
Does the advice remain the same ?
Best Regards,
Caspanis
