runLoganrun
- Jul 4, 2005
Hi,
I want to wire a dual 5mm led to a single 5mm led, and connect them to a switch, and prob a dimmer. other option- i found a 4 pin to 3x 2pin mini circuit adapter, i think this might be easier. the 4pin, of course, has two power leads, 5v & 12v i believe, how do i put a switch on this?
going to use either a basic rocker, or possibly a latching vandal switch.
is there a better way to do this?
what about the dimmer, will any fan type rheostat work?
thanks,
rlr
thanks,
rlr
