TaintedSquirrel
- Aug 5, 2013
Okay you were right, turning off vsync fixes it entirely.Not sure.
I'm on Win 7 64 bit pro. My CPU isn't as beefy as yours but if your sig is still current we're both on 980tis and we're both using 1920x1200 monitors and I haven't had any egregious performance issues and nothing like this. Between your 16Gb of RAM and the GPU VRAM you're well covered on memory. Should be no issues there.
I can go into the menu and turn it on, then when I go back into the game I'm at 20-20ms frametime. Then turn it off, in the same spot, shoots down to 16ms.
What the hell.
