just to close out my open ended quandary, I picked up the old Z87-ITX version today - they're in short supply (got 1 of 2 left on the shelf) - sometimes newer isn't always better I'm hoping
where did you get yours from? how much did you pay, if i may ask?
According to the manual, the last two SATA ports are shared with the M.2.
But isn't it possible to use a Ubuntu version installed onto a USB stick ? That way you don't need an SSD.
But the issue with the H97 and Z97 chipset is that it only supports 6 SATA-600 ports, others must come from a 3rd party chipset which no manufacturer does because it is already cramped. If you really need more than 6 ports on an mITX motherboard, you might best look at the ASRock C2750D4I board, one of the few mITX boards that has more than 6 SATA ports.
I bought my intel 7260AC card and installed it today, but have some weird issues. It works great with 2.4GHz and have better connection than before, but connecting to 5GHz causes Bluetooth to stop working and I can't connect to the internet. Tried the newest drivers and the default and new Bluetooth ones. Gonna uninstall and reseat and try other measures tomorrow after a bit of rest. If anyone has any great ideas, I'd be grateful!![]()
I just installed my 7260 AC last week and was having weird Bluetooth dropouts (and occasional wi-fi dropouts).
Some of the Intel techs suggested disabling U-APSD (a power saving feature), and that actually seems to have worked. Here are the step-by-step instructions that someone wrote up..
EDIT: Also, make sure you've uninstalled any software/drivers that were installed by a previous Bluetooth/Wi-Fi adapter.
mSATA is not the same as M.2, mSATA is compatible on the Z87E, but the Z97E has M.2.
Indeed, the Z87E only supports mSATA, the Z97E only supports M.2.
mSATA vs M.2 type 2242
While trying overclocking options, system stuck into an unstable overclock. It can't load Windows 8.1, locks on OS repair options. Also, my USB keyboard is unresponsive (dont have a PS2 one), so I can't enter BIOS to fix the problem. (By the way, a specified number (default 3) of boot failures option in BIOS is not working)
Is there a way (jumper configuration etc) to boot into BIOS directly? All I can find is to clear the CMOS by shorting the jumpers.
http://www.bleepingcomputer.com/forums/t/537916/intel-7260-wifi-adapter-with-bluetooth/#entry3396363
Is the built in wi-fi that shitty? I know this uses something like a 2TR2 or something wireless card which is also I think the technology the gigabyte board uses although that is an Intel card. Surprised to see this was a boardcom chip, but I thought Intel uses a lot of boardcom chips in their networking products?
I might be wrong. I am pushing around 30-35 on wireless N, but that maybe more my router than anything. I pay for 40 mb so it isn't too bad.
I replaced the Broadcom AC in my ASUS board with the Intel 7260 AC. I'm not aware of Intel using Broadcom in their chips, but to put it simply.. both AC chips are flaky as hell.
Throughput is great, it's just that both have issues where they will just randomly stop working for no reason. Using the Broadcom, connectivity was solid for mine, though 9 times out of 10 it would just not work at all when the system woke from sleep (regardless of settings, and required physically pulling the power plug to reset it).. Bluetooth worked 100% of the time with no issues. Using the Intel, there are generally no sleep issues, but out of nowhere, either the wifi or the bluetooth will just stop working for a little while (not always at the same time, and are almost always fixed by using Windows troubleshooting - or disabling/enabling the device). Haven't seen an update for the Broadcom driver for well over a year, and Intel is fully aware of the issues, and is constantly releasing new drivers trying to fix the problems (without much success).
Pick your poison, or maybe try an N-only card if you have any issues with the included card.
Lol, didn't notice there was a button at the back. Used jumpers to clear it. Thanks anyway.
I have a M.2 SSD for my Asus Impact that I was going to test on this board just for fun.Does anyone know what is the minimum fan speed is for a pwm CPU fan on this board? Is it 60% like on the Asus board?
Also, anyone has bootable M.2 SSD on this board? I was thinking of getting an AData 256 GB 2242 SSD, but not sure if the board supports it, and if it does, can it boot it?
I'll be doing a reformat and teardown of my Asus Impact build so I can test if it's bootable on my Asrock.Please do, and share results. There is very little information out there for M.2 SSDs, bootability, and this board. But since I discovered a 2242 256 GB one, I am tempted. Waste of money if the board doesn't see it, or doesn't boot from it, though.
