I built my first Micro-ATX system (I wanted a small PC... it'll help when I move!) and I decided upon an ASRock board. I'm beginning to nearly regret that decision already.
I can't seem to find a way to fix the voltage. If I set an auto or a minimal cpu voltage offset the board automatically jacks the voltage under load. Multiplier is at 42. Speedstep is off and the voltage offset controls do not allow me to fix a voltage. With minimal offset it spikes to 1.24v under load (vs 1.68v idle).
Am I missing a setting?
Edit: I found a way to fix the voltage, but according to RealTemp/ CPU-ID it is not responding to the voltage offset whatsoever.
2nd Edit: Oddly enough the second or third time I rebooted the settings seem to finally "stick." I can fix the voltage and adjust it properly. Phew!
