I woke up this morning to an unresponsive PC. No fans, no response from power or reset buttons, nothing. The only board does is cycle the RGB on the RAM and pulse the blue LEDs around the northbridge. I've pulled the power cable and let it sit for a few minutes, but as soon as I plug it in, it does the same thing. Nothing on the diagnostic LED... nothing. It doesn't even try to boot. I normally leave it running 24/7.
Everything has been working fine, with the exception of XMP. I built the system a few weeks ago and it's been running solid. The G.Skill memory is *supposed* to do PC3200, but if I try to set it to the XMP profile in BIOS, it just beeps four times, then boots up and the normal 1066mhz. I haven't had time to set the RAM manually, so I've just left it for now.
The only other problem I had was a C0 on the diagnostic output when I tried to boot with 4 x 8GB sticks. I updated the BIOS and that was resolved.
Here is a video of it doing absolutely nothing. Disregard the fan noise in the background. That is from my servers, and not from the PC:
