I need a new budget board, preferably SLi chipset so I can upgrade later in the future.
My current Asus A8N-SLi Deluxe is dead(probably static discharge or something), and the warranty is void(don't ask), therefore I need a new board, and I can't afford to spring $180CAD for the Deluxe again.
My only options are really:
Asrock 939SLI32-eSATA2 $132CAD
Asus A8N-SLi standard(not deluxe) $153CAD
DFI nF4 SLi Infinity $132CAD
I'm not really looking into overclocking all that much(highest I can go on stock cooling/voltages). The rig is in my sig.
I have to buy from a local store, so don't suggest to shop elsewhere.
I'm partial to the Asus, considering I had the A8N-SLi Deluxe and really liked it(bundle, the board layout, the mosfet cooling, etc). Then again, is the standard worth $20 more than the others?
Also, the Asus is the only board that can support surround sound(3 plugs) and a microphone. The others don't seem to have enough connectors.
[edit] Apparently I can connect my surround speakers to it using the 3 plugs, but how would I connect my microphone?
