ASrock 939Dual-Sata2 connecting more than 2 drives
anthrex
I was wondering if its possible to connect more than 1 optical drive on my 939dual. RIght now I only see one CD1 audio input and I have it connected to a dvd burner and I'd also like to connect a CD burner without losing any audio for it. Thanks
Dark_fire
you wont lose audio, as it goes digital over the IDE cable. with xp you dont really need it. if not you can find a y cable to connect both onto the same audio cable
anthrex
Ok thanks,
I don't want to make another thread, but I was wondering there was anywayI could get my Arctic Cooling 64 Pro to fit on my mobo. Some guy in the big long Asrock thread that I should get it and that there would be no clearance issues, but I tried and it won't fit on the processor because the southbridge heatsink is in the way. I can get the heatsink into the slots, but its not possible to move the retention lever (or whatever its called). I could really use some advice on installing this heatsink on my mobo. thanks
uniwarp
How do you like this board ? I want to recommend it to a friend due to its specifications but I want to know if you are pleased with it? Have you tried OC'ing yet ? Is it stable ? All input appreciated.
Dark_fire
you are putting it on backwards, the lever should be on top and the fan should be close to the ram
