Exactly what I was thinking as well, lolpulse has reviews and challenger doesn't. Challenger is in stock on newegg, but no refund policy, exchange only. I am not sure why there are 0 reviews for the challenger yet even though its in stock already. However newegg will refund you if the item you are returning is not in stock. Heatsink doesn't look bad though, looks like some fat heatpipes on it.
i'm jealous, the AIB boards still aren't available on newegg.ca
i'm just waiting for any of the AIB boards to be instock so i can buy it >< Seriously tempted to just get a reference model right now.
Didn't feel like spending that much extra on a card that realistically can only be overclocked a very small amount so I went ASRock. I prefer the aesthetics of the Sapphire Pulse but figured for the same price the slight OC on the ASRock was nice. I originally wanted the Gigabyte as my last card was a Gigabyte WindForce HD 6950 that has lasted 8 years with 0 issues, but again, didn't feel like paying $20 over the stock price.I think the AIB stuff will start trickling out soon. You can hold out, I think you'd end up being a bit sad if you went for a reference with AIB's right around the corner. The struggle is real though....I could have bought the ASRock version yesterday, but I am holding out for the Red Devil.
I wanted a Gigabyte card, too, but wasn't willing to wait for them. So it became a choice between the Sapphire Pulse and ASRock Challenger. Challenger won out because it came in stock first. It gets here Monday. I wasn't worried that it has no reviews, or that no one has gotten a review sample yet. I don't see how it can be any worse than the blower cards, even if it comes out at the bottom of the AIB card stack.
Either way, if I don't like it, I will likely be able to get my money back on eBay, or locally on Marketplace. I am not giving up my 1070 right away anyhow, so I have a backup plan if I end up ditching it for a different card.
Having owned several V56/64/VIIs (all under water) and a 5700XT 50th AV I would say either buy the 5700xt or a used reference V56 for 230 on eBay and a $65 HSF....That will give you the best bang for the buck, and it ensures you get a card with Samsung HBM.actually i am tempted to get a vega 56. I guess they are on clearance now and i see them going for about 360 while a reference 5700 is 100bucks more. How patient do i want to be... gah.. I am a little worried about the AIB tax that will hit on these 57xx cards.
Good to hear, I definitely am not happy with my experience so far.I just installed my ASRock Challenger, and as so far have had no issues. Will report back once I play a game or three.
Well, that doesn't instill any confidence. I guess Newegg must have known they're crap with the exchange only return policy.
Can always bring up lemon law and the Magnuson-Moss Warranty Act https://en.wikipedia.org/wiki/Magnuson–Moss_Warranty_Act both of which absolutely apply here. Could also try contact your credit card company and see what happens.Woke up this morning after another Windows reinstall, and used DDU to uninstall the 19.8.2 drivers, thinking maybe if I try the 19.8.1 drivers things might clear up. Well, they didn't. I was really hoping it was just a driver issue. But after the restart for the older drivers it hung, which meant on next start up it would be another Video Scheduler BSOD.
Yeah, the replacement only return policy is going to be a major sticking point for this, I can see that now. No matter who I contact it looks like I am almost guaranteed to be stuck with this card. I can't be too many more mfr's beta test squad.
I guess it's back to the old GTX 1070 for now.
Not sure it matters, but for posterity, my system config is:
Ryzen 7 3700X, 32GB G.Skill TridentZ 3200 CL16, Asus Prime X370-Pro.
I do not believe myself to be running a BIOS that has PCI-e 4.0 enabled, as I am on an X370 board. I will look into that shortly.
I am currently on the drivers that came with the motherboard, I will be updating those shortly.
PM coming your way.
Edit:
Do I check the PCI-e 4.0 thing while that card is installed? There is no option in the BIOS with the 1070 installed.
maybe before sending it back, pull the heatsink off and see if they're doing something stupid with the cooling..
nah newegg does it for most new product releases, doesn't matter what brand it is.
My 5700xt would BSOD after a fresh OS install too. Untill I installed every single Windows update and then ran DDU again.
I updated to the latest drivers for everything for the Asus Prime X370-pro last night.
I installed all of the Windows updates that were available last night.
I ran DDU to uninstall the GTX 1070 this morning.
I installed the RX 5700 XT this morning.
I powered my PC back on and installed the Radeon drivers 19.8.2 this morning.
There was no BSOD this startup, but we are still early in the game.
Ok, according to GPU-Z, it is indeed running at PCI-e 4.0 ( PCIe x16 4.0 @ x16 1.1 ).
Please advise.
Edit:
After a few minutes of browsing Firefox, it gave me a BSOD for Video TDR Failure, which when it restarted, it hit me with another Video Scheduler BSOD.
Edit 2:
Couldn’t get driver to install in safe mode after another uninstall, hard shutdown while trying to reinstall the driver.
you can reinstall the drives a million times, the problem isn't the drivers.. it's going to be related to 1 of 3 things.. your gpu, your motherboard/bios, or a hard drive issue(likely isn't the case if you're using an SSD) which are the 3 primary causes of the error.
also your card isn't running at pcie x16 4.0.. all it's saying is that it can run at that and the second set of numbers after the @ is what it's actually running at so there's definitely a problem either on the card it's self or the board but given your 1070 runs fine doubt that's the problem but if you haven't checked gpu-z with it installed may want to try that.
I was under the impression that the x370 Prime Pro did indeed have 4.0 enabled (for now) but at x8 only for the primary 16x slot.
Asus is slowly pushing updates to remove this. Either this is the issue or he has a bad card. It sucks but it's entirely possible it just is a defective card.
My 5700XT Challenger is on its way to Newegg, won't get there until next Wednesday and then they say 2-4 days before they ship a replacement, and they probably will still be out of stock even then. Wondering what they do if the card is out of stock, do they make you wait or offer a refund?
even if it was available, his cards not running at that, it's running at x16 1.1. if it was running at 4.0 it would say PCIe x16 4.0 @ x16 4.0.
I could always call the CC company too, they usually protect you.they usually keep some set aside for returns but if they say you'll have to wait i'd use that to demand a refund or force them to exchange it with another card like the pulse or something.
Good luck.BIOS updated. I ran the render test in GPU-z and it runs @ x16 3.0. I also fired up SotTR and returned a 117 FPS avg, so I am going to guess that when PUBG installs I will get more than 60FPS. I hope this is it. I hope this is the end of it.
