pippenainteasy
- May 20, 2016
Owned by the same company as Tom's Hardware and they were considered the secondary website, and now, all the resources are going to THG.I mean why anandt go down.
That's impressive, given it doesn't use Hyperthreading. It does more with less... I am getting AMD FX series / Bulldozer (that actually work) kind of vibes off of the new chips. Their GPUs supposedly outrun AMD Strix point APUs at lower wattage. But they get crushed as they don't scale with power draw and the AMD APUs do. Still, very impressive that Intel can match AMD's graphics and outstrip them at all in 2 generations (technically 3).
Do not get the potentially 2 time the bandwidth of zen5 talk, I could be missing the point of the 7 minute video format with random images, I feel this is a old video re-released, with percentage just out of a bit nowhere:
3 weeks ago:
View: https://www.youtube.com/watch?v=rmiujWgfOfQ&t=297s
On AM5 the sweet spot for performance is ~6000 and CL as low as you can get. A little more MHz if you have a good chip. Go too fast and you have to lower the clock speed on the memory controller. It's not just about how many GB/s it can move, it's also how long between the CPU wanting whatever is at X address and the ram & memory controller delivering it. Assuming that guy is right about the 64GB/s limit between a CCD and the I/O die (I have no personal knowledge of this, though I am now curious to read up on it), that means that on AMD latency is basically everything... unless you have a multithreaded workload on a CPU with more than one CCD. It's 64GB/s per CCD, not 64GB/s for the entire CPU package. Hopefully this makes sense.I think this a bit going over my head as we often see gain to zen5 going over ddr5-4000 in dual channel (that when you hit the 64GBps limit).
12th, 13th, and 14th gen intel also run their DDR5 in Gear 2.The claim is that the Infinity fabric that connects the CCDs to the IO die can only manage 64GB/s, so no matter what ram you hook up to an AM5 chip that's all you'll get. Meanwhile Intel chips don't have this limitation, and can take full advantage of faster ram. Or maybe not, as some of the articles about CUDIMMs (clocked unbuffered DIMMs, can run at 9000+) say they'll have to run in gear 2, so memory controller at half speed. That could result in a situation similar to what we see with AMD where there's a sweet spot for ram speed. Still, the i9-14900K is already ahead on DRAM bandwidth, and one would expect Arrow Lake to improve on that.
Which is significantly more bandwith (96gbps) than 64gbs in dual channel, thus my point. Many ryzen cpu are single CCD and still take advantage of faster than 4000 MT/s ram (the frequency needed to reach 64GBps).On AM5 the sweet spot for performance is ~6000 and CL as low as you can get.
Sorry, the leak/rumor is about Arrow Lake. If it can run 9000+ in gear 2, we could end up with a situation where you can run 4800 or 5000 or something like that in gear 1, thus potentially creating a sweet spot, at least as far as cost goes.12th, 13th, and 14th gen intel also run their DDR5 in Gear 2.
Yes and my point is that Intel chips already run in Gear 2, and still benefit a lot from faster RAM. Faster the better. (Alrhough 6000 with optimized timings competes well with 7200).Sorry, the leak/rumor is about Arrow Lake. If it can run 9000+ in gear 2, we could end up with a situation where you can run 4800 or 5000 or something like that in gear 1, thus potentially creating a sweet spot, at least as far as cost goes.
Me too, but the latest benchmark I saw indicates weak performance. In the benchmark it performs worse than a 14900 (non K), worse than the AMD 9700X by a wide margin (especially in multithreading)... It could be a step back before leaping forward. I suspect any gains in this generation should (theoretically) be from efficiency gains. Can't find the article anymore so hopefully it was misrepresented.Less than a month to go now. Hoping for the best from Arrow Lake.
I don't think that is enough to matter. That's a lot less difference from center, than Ryzen's compute chiplet is. And even adjusting for that is only about 3C better.https://wccftech.com/intel-arrow-lake-cpus-lga-1851-hotspot/
Cooling companies might need to retool their cooling blocks for Arrow Lake. Hot spot is further North instead of dead center.
