Around $250 speakers to connect to my PC for small room.
professional loser
I work from home 100% and looking for white speakers to connect to my PC. I was using Creative GigaWorks T40 previously, but my wife had taken them. Want to upgrade, was looking at Creative T40 Version II ($120), but the newer version seem to have some green power saving feature that apparently gets irritating as you miss the first few seconds of sound when waking up.
Some of the speakers that I have been looking at now are-
Audioengine A5+, $358 (plenty of connection options to connect directly to the PC)
A̶u̶d̶i̶o̶e̶n̶g̶i̶n̶e̶ ̶A̶2̶+̶,̶ ̶$̶3̶0̶0̶ ̶(̶c̶o̶n̶n̶e̶c̶t̶s̶ ̶d̶i̶r̶e̶c̶t̶l̶y̶ ̶t̶o̶ ̶P̶C̶)̶
* Cambridge Audio Minx XL, $130 (instead of $160) + DAC?
* Dali Spektor 2, $250 + DAC?
* Will need a DAC for some of them I think to connect to PC??? Any reliable and cheap recommendations? Need to factor that in the cost!
Edit- Ok I am now confused, do I need an Amplifier or DAC to connect to the PC :-P
Quality + Bang for the buck is what I am after :) Btw I listen to all kind of music, from classical to electronic etc etc.
pendragon1
you will need either an amp for bookshelf sets, most dacs have a bit of an amp in the but you might need a bigger unit.
fluance makes some nice self powered bookshelf systems that are white faced, side are still wood grain.
audioengine a5+ look nice too.
Wiz33
Might want to read this thread.
https://hardforum.com/threads/good-compact-2-0-setup-pc-music-some-movies-occasional-gaming.2010032/
With Powered speakers, you don't need an Amp. Weither you need a DAC all depends on what kind of music format you listen to but generally (you definitely want one if you have 24bit music), having even a low price US DAC will give you better sound quality since you're doing all the D2A away from all the EM noise inside a PC case. Do a search fo USB DAC and see.
atarione
This for $50~ (plus power supply unless you buy it with a PSU on Ali or ebay?) mine was $45 with a 19V psu on Ali (took 3~weeks to get here however)
Nobsound NG-04G Pro .. this thing is pretty decent.. I can't complain really.
and whatever bookshelf speakers you can want... Them Dali / Cambridge options look great
professional loser
Nobsound NS-15G PRO Bluetooth 5.0 Digital Amplifier PCM5102A Decoding 100W×2 with Power Supply (NS-15G PRO)​
It is selling for $140 in my country in Europe. Plus I keep reading that it is a fire hazard!!!??
Are there any reasonably priced reputable brands instead?
professional loser
A5+ would be straight forward, no amp etc required, but I keep reading that it is too much hype rather than quality?
pendragon1
reviews look good to me. theres a few "damaged when i got it" and the big complaints seem to be no headphone jack and limited remote functions. if interested in them, watch read some more reviews i guess. your call though.
professional loser
Yes, have not counted it out yet.
Btw Cambridge Audio Minx XL, 2 @ $130 got sold out while I was busy reading and watching reviews! It is like a rabbit hole, you get sucked in lol. Plenty of Minx XL still available but at $160.
Local European prices.
