Argb hub options other then Corsair commander?
Hokies83
Fritzz
What fans are you looking to control? Did you buy them in a 3 pack(asking because most 3 packs come with a controller)? Also the RGB fans have a proprietary connector for Corsair products, unless you want to do some cutting and soldering.
If you have just fans then I think you will at the very least need the following. Hard to know until you let us know what you have.
https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Cooling/CORSAIR-HD-RGB-Fan-LED-Controller/p/CO-8950022#tab-overview
https://www.corsair.com/us/en/Categories/Products/Custom-Cooling/Accessories/CORSAIR-RGB-Fan-LED-Hub/p/CO-8950020
Or the better option IMO is(because you can hook it directly to you mobo and control it with iCUE)
https://www.corsair.com/uk/en/Categories/Products/Accessories-|-Parts/iCUE-CONTROLLERS/CORSAIR-Lighting-Node-PRO/p/CL-9011109-WW
Hokies83
Corsair h100 platinum + 3 Corsair HD120 that came with the little controller.
Decided to spend and got a commander pro to hook all of them up to and sync in icue,
My mb has no Jcorsair port :(
