Anyone tried current Areca drivers on win 10?![]()
6.20.00.31 Storport 64bit works fine with 10 Build 10162 on the 1883.
I have 7 500Gb drives setup in RAID 5. It has been running for years without a problem. I decided to upgrade and replaced the 500Gb disks with Seagate 1Tb disks. When I rebooted the system, the RAID controller now has a message "No BIOS disk found. RAID Controller BIOS not installed" when I hit tab/F6 the Bios screen pops up and is empty. I put all the 500Gb disks back and connected them in the proper order. Rebooted and all is well. How can I fix the controller so it works with 1Tb drives or correct the "No BIOS" message. Thanks in advance. . . . . . AsForMe
Blue Fox - here is my original post "I have 7 500Gb drives setup in RAID 5. It has been running for years without a problem. I decided to upgrade and replaced the 500Gb disks with Seagate 1Tb disks. When I rebooted the system, the RAID controller now has a message "No BIOS disk found. RAID Controller BIOS not installed" when I hit tab/F6 the Bios screen pops up and is empty. I put all the 500Gb disks back and connected them in the proper order. Rebooted and all is well. How can I fix the controller so it works with 1Tb drives or correct the "No BIOS" message. Thanks in advance. . . . . . AsForMe"
Hey guys, I could use some help now. I was rendering a video out today and I came back to my desk to find my computer restarted itself and it was showing on the bootup screen in red something to likes of 'insufficient memory' where it normally starts the firmware!
I tried rebooting again but only to find the F/W boot screen going past the 300 seconds mark and restarting itself.
I just recently purchased a 4gb stick of ram as per my previous post on here but changing that out with the old 1gb stick of ram does not solve the issue either!! The only thing that I'm seeing is the firmware boot screen but it goes over 300 seconds and then reboot.
For now I have removed the card and using my PC without it. Of course, all my footage is backed up and I have my current project transferred over to a 6tb raid 0 setup on my computer but I have no idea what to do now with the 1882ix. I should still be under the 3 year warranty but this is a pretty huge hassle either way. Not sure if it had to do with the new ram installed either (it was purchased from the Areca website).
Any advice or help would be appreciated!!!
Hey guys I need help.
I can't seem to get my RAID card working, but it shows up in Windows, so it can't be broken.
It's an ARC-1222.
motherboard is a gigabyte GA-970A-UD3 (not sure which rev I can check if necessary)
When the Areca is inserted, it gives the two short beeps when the system boots up, and I see NO special post screen to initialize the hard drives. I heard it is supposed to be after the normal POST and before the OS, but it goes straight to the OS. In windows, it asked for a driver and I gave it the proper one. Says it is installed correctly, but I can't see drives which are connected to it. Since this is sort of a hardcore adapter I suppose the drives have to be set up in that BIOS screen.
Is there some option in my mobo bios I have to enable?
Hello!
I have a question (already contacted Areca support, but just hours ago, so no reply yet) about the Areca Ethernet port and also the in-band management.
So, I'm preparing a new workstation with direct-attached storage using this brand-new ARC-1883ix-12 here. Currently, I only have two Seagate Cheetah 15k.6 on it for testing.
Yesterday, everything worked fine. I shut the machine down, and as I booted it up today, everything "seemed" fine. Firmware posts, detects the PCIe link, detects my test RAID, all ok. However, the Ethernet port which I use to control the system stayed dead! The LEDs? Dark. So I thought, let's try the Web proxy on the OS itself, right? It's Windows by the way. But the in-band management (http://127.0.0.1:81) says it can't connect either, no server there.
So I tried accessing SMART data via smartmontools, which works just fine. The Areca CLI (and the BIOS btw.) also work just fine. And of course, the disk array is there and usable in the OS. Both devices (the StorPort driven controller and this "Virtual SCSI RAID Device" for SMART access and other things) are there in device manager and appear to be ok. There are NO errors logged whatsoever, not in the Areca firmware log, nor in Windows system or MCRAID logs.
It seems to me that there are two "access channels" to the boards management interface, one seems to be RS232, the other Ethernet, with both being accessible via some means over the PCIe interface too. The CLI seems to be accessing the RS232 subsystem of the board, which still works (i might be wrong, but so the tray tools report it), and the web proxy gets to the onboard LAN?
It appears the LAN on the card is broken?! Is there anything I should/could do? I mean, this is pretty much a brand-new board. Maybe somebody has encountered this before and knows how to fix it.
Temps by the way were 35°C for the board, 65-70°C for the PowerPC CPU and 55-58°C for that other chip... SAS expander maybe I'm guessing. And the flash backup module sat nicely at 32°C. Should be within acceptable parameters I presume.
Any ideas?
Thanks!
Can you please post the entire log from the card? Is it just one drive or entire rows?Any ideas on what is wrong? Or other settings I should change?
Thanks! Hammer8
Here's the log...I moved the enclosure to a 1880 card and the timeouts disappeared. Maybe the SC847 is not compatible with the 1882? However, I've used the combination before and never had any problems. The array in question is in Enc#6. Thanks!
You are losing the whole domain, so check power first, SAS cabling second and change the card if those are fine (which you did). Sounds like either the card or connectors on your 1882 are going bad, but the 1882 and SC847 are perfectly compatible.
Hi. I bought a used Areca 1260 card (16x sata ports ) to my home server. For few days everything worked fine with couple installed hdds. Yesterday when I finally connect all drives and all cables, card didnt work. It always emit a long beep on start (with blinking at different frequencies green light) / after that I had window " waiting for f/w to become ready".
Now card is even not recognized in mobo slot and green light (D1) blinks fast all the time. What is wrong with it? I tried on other computers but it is the same. Is it broken or what?
Wondering if anyone can help me. I have an Areca 1880i with a 34TB RAID6 array on a Windows 2008 R2 system. A drive went bad today and the array immediately started rebuilding with a hot spare. The array is still rebuilding (34% done). I noticed that certain directories on the server were inaccessible. I decided to reboot the system. Now Windows is labeling the array as an invalid dynamic drive (GPT).
Is there anything I can try?
Please post the entire log from the card. Do you have a current backup of the array?
2015-12-09 15:30:42 ARC-1880-VOL#000 Start Rebuilding
2015-12-09 15:30:27 192.168.001.001 HTTP Log In
2015-12-09 15:30:19 H/W Monitor Raid Powered On
2015-12-09 15:26:02 ARC-1880-VOL#000 Stop Rebuilding 000:55:22
2015-12-09 15:14:26 192.168.001.001 HTTP Log In
2015-12-09 14:30:39 ARC-1880-VOL#000 Start Rebuilding
2015-12-09 14:30:17 H/W Monitor Raid Powered On
2015-12-09 14:29:23 ARC-1880-VOL#000 Stop Rebuilding 002:16:09
2015-12-09 12:21:21 192.168.001.001 HTTP Log In
2015-12-09 12:13:14 ARC-1880-VOL#000 Start Rebuilding
2015-12-09 12:13:14 ARC-1880-VOL#000 Abort Checking 000:05:45 1
2015-12-09 12:13:13 Enc#2 Slot#1 Device Failed
2015-12-09 12:13:13 RAID6 Rebuild RaidSet
2015-12-09 12:13:13 RAID6 RaidSet Degraded
2015-12-09 12:13:13 ARC-1880-VOL#000 Volume Degraded
2015-12-09 12:12:45 Enc#2 Slot#1 Time Out Error
2015-12-09 12:07:28 ARC-1880-VOL#000 Start Checking
Please post the entire log, going back to before the event. 19 members in a single array is more than recommended. Do you have (preferably) 19 available 2TB drives to image your array or an additional 34TB of space to image your current drives so you can always return to your current level if the recovery attempts make things worse?
2015-12-09 11:40:26 ARC-1880-VOL#000 Stop Checking 001:02:58 0
2015-12-09 10:37:28 ARC-1880-VOL#000 Start Checking
2015-12-09 10:31:30 ARC-1880-VOL#000 Stop Checking 000:15:01 0
2015-12-09 10:16:28 ARC-1880-VOL#000 Start Checking
2015-12-09 09:19:26 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-12-09 09:07:28 ARC-1880-VOL#000 Start Checking
2015-12-09 08:58:26 ARC-1880-VOL#000 Stop Checking 000:32:58 0
2015-12-09 08:25:28 ARC-1880-VOL#000 Start Checking
2015-12-09 07:52:26 ARC-1880-VOL#000 Stop Checking 005:38:58 0
2015-12-09 07:38:27 192.168.001.001 HTTP Log In
2015-12-09 02:13:28 ARC-1880-VOL#000 Start Checking
2015-12-09 02:08:01 H/W Monitor Raid Powered On
2015-12-09 02:03:42 ARC-1880-VOL#000 Stop Checking 003:38:58 0
2015-12-08 22:24:44 ARC-1880-VOL#000 Start Checking
2015-12-08 21:36:42 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-12-08 21:09:44 ARC-1880-VOL#000 Start Checking
2015-12-08 20:33:42 ARC-1880-VOL#000 Stop Checking 000:20:58 0
2015-12-08 20:12:44 ARC-1880-VOL#000 Start Checking
2015-12-08 20:03:43 ARC-1880-VOL#000 Stop Checking 000:20:58 0
2015-12-08 19:42:44 ARC-1880-VOL#000 Start Checking
2015-12-08 18:57:43 ARC-1880-VOL#000 Stop Checking 001:26:58 0
2015-12-08 17:30:45 ARC-1880-VOL#000 Start Checking
2015-12-08 17:24:43 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-12-08 17:12:45 ARC-1880-VOL#000 Start Checking
2015-12-08 16:54:43 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-12-08 16:48:45 ARC-1880-VOL#000 Start Checking
2015-12-08 16:18:43 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-12-08 16:15:45 ARC-1880-VOL#000 Start Checking
2015-12-08 16:06:43 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-12-08 15:54:45 ARC-1880-VOL#000 Start Checking
2015-12-08 15:09:43 ARC-1880-VOL#000 Stop Checking 000:23:58 0
2015-12-08 14:45:45 ARC-1880-VOL#000 Start Checking
2015-12-08 13:45:43 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-12-08 13:18:45 ARC-1880-VOL#000 Start Checking
2015-12-08 13:09:43 ARC-1880-VOL#000 Stop Checking 001:11:58 0
2015-12-08 11:57:45 ARC-1880-VOL#000 Start Checking
2015-12-08 11:33:43 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-12-08 11:30:45 ARC-1880-VOL#000 Start Checking
2015-12-08 11:24:43 ARC-1880-VOL#000 Stop Checking 000:35:58 0
2015-12-08 10:48:45 ARC-1880-VOL#000 Start Checking
2015-12-08 09:48:43 ARC-1880-VOL#000 Stop Checking 001:29:58 0
2015-12-08 08:18:45 ARC-1880-VOL#000 Start Checking
2015-12-08 07:51:43 ARC-1880-VOL#000 Stop Checking 001:23:58 0
2015-12-08 06:27:45 ARC-1880-VOL#000 Start Checking
2015-12-02 08:28:44 192.168.001.001 HTTP Log In
2015-12-01 06:26:27 ARC-1880-VOL#000 Complete Check 007:46:38 0
2015-11-30 22:39:48 ARC-1880-VOL#000 Start Checking
2015-11-30 22:09:47 ARC-1880-VOL#000 Stop Checking 000:08:58 0
2015-11-30 22:00:48 ARC-1880-VOL#000 Start Checking
2015-11-30 21:06:46 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-30 21:03:48 ARC-1880-VOL#000 Start Checking
2015-11-30 20:45:09 192.168.001.001 HTTP Log In
2015-11-30 20:39:46 ARC-1880-VOL#000 Stop Checking 002:02:58 0
2015-11-30 18:36:49 ARC-1880-VOL#000 Start Checking
2015-11-30 18:30:48 ARC-1880-VOL#000 Stop Checking 001:29:58 0
2015-11-30 17:00:49 ARC-1880-VOL#000 Start Checking
2015-11-30 16:54:47 ARC-1880-VOL#000 Stop Checking 008:02:58 0
2015-11-30 08:51:49 ARC-1880-VOL#000 Start Checking
2015-11-30 07:57:47 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-11-30 07:45:49 ARC-1880-VOL#000 Start Checking
2015-11-30 07:40:22 H/W Monitor Raid Powered On
2015-11-27 16:49:45 192.168.001.001 HTTP Log In
2015-11-26 10:20:47 ARC-1880-VOL#000 Complete Check 002:17:05 0
2015-11-26 08:03:42 ARC-1880-VOL#000 Start Checking
2015-11-26 07:42:40 ARC-1880-VOL#000 Stop Checking 000:20:58 0
2015-11-26 07:21:42 ARC-1880-VOL#000 Start Checking
2015-11-26 07:06:40 ARC-1880-VOL#000 Stop Checking 004:11:58 0
2015-11-26 02:54:42 ARC-1880-VOL#000 Start Checking
2015-11-26 00:54:41 ARC-1880-VOL#000 Stop Checking 001:08:58 0
2015-11-25 23:45:42 ARC-1880-VOL#000 Start Checking
2015-11-25 23:39:40 ARC-1880-VOL#000 Stop Checking 000:47:58 0
2015-11-25 22:51:42 ARC-1880-VOL#000 Start Checking
2015-11-25 22:09:40 ARC-1880-VOL#000 Stop Checking 004:50:58 0
2015-11-25 17:18:42 ARC-1880-VOL#000 Start Checking
2015-11-25 16:03:40 ARC-1880-VOL#000 Stop Checking 000:17:58 0
2015-11-25 15:45:42 ARC-1880-VOL#000 Start Checking
2015-11-25 15:15:40 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-25 15:09:42 ARC-1880-VOL#000 Start Checking
2015-11-25 15:03:40 ARC-1880-VOL#000 Stop Checking 000:29:58 0
2015-11-25 14:33:42 ARC-1880-VOL#000 Start Checking
2015-11-25 14:00:40 ARC-1880-VOL#000 Stop Checking 001:11:58 0
2015-11-25 12:48:42 ARC-1880-VOL#000 Start Checking
2015-11-25 12:30:40 ARC-1880-VOL#000 Stop Checking 001:17:58 0
2015-11-25 11:12:42 ARC-1880-VOL#000 Start Checking
2015-11-25 11:06:41 ARC-1880-VOL#000 Stop Checking 002:14:58 0
2015-11-25 08:51:42 ARC-1880-VOL#000 Start Checking
2015-11-25 08:48:40 ARC-1880-VOL#000 Stop Checking 000:35:58 0
2015-11-25 08:12:42 ARC-1880-VOL#000 Start Checking
2015-11-17 11:04:54 ARC-1880-VOL#000 Complete Check 000:01:07 0
2015-11-17 11:03:47 ARC-1880-VOL#000 Start Checking
2015-11-17 09:03:45 ARC-1880-VOL#000 Stop Checking 001:44:58 0
2015-11-17 07:18:47 ARC-1880-VOL#000 Start Checking
2015-11-17 07:12:45 ARC-1880-VOL#000 Stop Checking 009:47:58 0
2015-11-16 21:24:47 ARC-1880-VOL#000 Start Checking
2015-11-16 20:39:45 ARC-1880-VOL#000 Stop Checking 006:35:58 0
2015-11-16 14:03:47 ARC-1880-VOL#000 Start Checking
2015-11-16 13:48:46 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-11-16 13:21:47 ARC-1880-VOL#000 Start Checking
2015-11-16 12:45:42 ARC-1880-VOL#000 Stop Checking 000:41:58 0
2015-11-16 12:03:43 ARC-1880-VOL#000 Start Checking
2015-11-16 10:06:41 ARC-1880-VOL#000 Stop Checking 000:08:58 0
2015-11-16 09:57:43 ARC-1880-VOL#000 Start Checking
2015-11-16 09:45:41 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-11-16 09:33:43 ARC-1880-VOL#000 Start Checking
2015-11-16 09:15:41 ARC-1880-VOL#000 Stop Checking 000:08:58 0
2015-11-16 09:06:43 ARC-1880-VOL#000 Start Checking
2015-11-16 07:18:09 192.168.001.001 HTTP Log In
2015-11-16 06:58:20 H/W Monitor Raid Powered On
2015-11-14 07:57:02 ARC-1880-VOL#000 Complete Check 008:44:56 0
2015-11-13 23:12:06 ARC-1880-VOL#000 Start Checking
2015-11-13 19:39:04 ARC-1880-VOL#000 Stop Checking 002:11:58 0
2015-11-13 17:27:06 ARC-1880-VOL#000 Start Checking
2015-11-13 16:57:04 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-13 16:54:06 ARC-1880-VOL#000 Start Checking
2015-11-13 16:00:04 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-13 15:57:06 ARC-1880-VOL#000 Start Checking
2015-11-13 14:42:05 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-11-13 14:15:06 ARC-1880-VOL#000 Start Checking
2015-11-13 13:57:04 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-13 13:54:06 ARC-1880-VOL#000 Start Checking
2015-11-13 13:48:05 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-13 13:45:06 ARC-1880-VOL#000 Start Checking
2015-11-13 12:36:05 ARC-1880-VOL#000 Stop Checking 001:32:58 0
2015-11-13 11:03:06 ARC-1880-VOL#000 Start Checking
2015-11-13 10:33:05 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-11-13 10:06:06 ARC-1880-VOL#000 Start Checking
2015-11-13 09:57:04 ARC-1880-VOL#000 Stop Checking 000:53:58 0
2015-11-13 09:03:06 ARC-1880-VOL#000 Start Checking
2015-11-13 07:30:05 ARC-1880-VOL#000 Stop Checking 005:20:58 0
2015-11-13 02:09:06 ARC-1880-VOL#000 Start Checking
2015-11-13 02:03:39 H/W Monitor Raid Powered On
2015-11-13 02:02:44 ARC-1880-VOL#000 Stop Checking 004:08:58 0
2015-11-12 21:53:46 ARC-1880-VOL#000 Start Checking
2015-11-12 21:17:44 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-11-12 21:05:46 ARC-1880-VOL#000 Start Checking
2015-11-12 19:29:44 ARC-1880-VOL#000 Stop Checking 002:11:58 0
2015-11-12 17:17:46 ARC-1880-VOL#000 Start Checking
2015-11-12 16:38:44 ARC-1880-VOL#000 Stop Checking 000:35:58 0
2015-11-12 16:02:46 ARC-1880-VOL#000 Start Checking
2015-11-12 15:02:44 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-11-12 14:35:46 ARC-1880-VOL#000 Start Checking
2015-11-12 14:20:44 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-11-12 14:08:46 ARC-1880-VOL#000 Start Checking
2015-11-12 13:50:44 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-12 13:47:46 ARC-1880-VOL#000 Start Checking
2015-11-12 13:32:45 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-12 13:26:46 ARC-1880-VOL#000 Start Checking
2015-11-12 13:08:44 ARC-1880-VOL#000 Stop Checking 001:14:58 0
2015-11-12 11:53:46 ARC-1880-VOL#000 Start Checking
2015-11-12 11:47:44 ARC-1880-VOL#000 Stop Checking 000:08:58 0
2015-11-12 11:38:46 ARC-1880-VOL#000 Start Checking
2015-11-12 10:56:44 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-12 10:53:46 ARC-1880-VOL#000 Start Checking
2015-11-12 10:47:44 ARC-1880-VOL#000 Stop Checking 000:14:58 0
2015-11-12 10:32:46 ARC-1880-VOL#000 Start Checking
2015-11-12 08:31:22 192.168.001.001 HTTP Log In
2015-11-11 02:12:19 H/W Monitor Raid Powered On
2015-11-11 00:22:26 ARC-1880-VOL#000 Stop Checking 002:26:58 0
2015-11-10 21:55:28 ARC-1880-VOL#000 Start Checking
2015-11-10 21:52:26 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-10 21:46:28 ARC-1880-VOL#000 Start Checking
2015-11-10 20:55:26 ARC-1880-VOL#000 Stop Checking 000:11:58 0
2015-11-10 20:43:28 ARC-1880-VOL#000 Start Checking
2015-11-10 20:16:27 ARC-1880-VOL#000 Stop Checking 000:20:58 0
2015-11-10 19:55:28 ARC-1880-VOL#000 Start Checking
2015-11-10 19:52:26 ARC-1880-VOL#000 Stop Checking 001:50:58 0
2015-11-10 18:01:28 ARC-1880-VOL#000 Start Checking
2015-11-10 16:43:26 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-10 16:37:28 ARC-1880-VOL#000 Start Checking
2015-11-10 16:25:27 ARC-1880-VOL#000 Stop Checking 001:08:58 0
2015-11-10 15:16:28 ARC-1880-VOL#000 Start Checking
2015-11-10 14:25:27 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-10 14:19:28 ARC-1880-VOL#000 Start Checking
2015-11-10 14:04:26 ARC-1880-VOL#000 Stop Checking 000:17:58 0
2015-11-10 13:46:28 ARC-1880-VOL#000 Start Checking
2015-11-10 13:04:27 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-11-10 12:37:29 ARC-1880-VOL#000 Start Checking
2015-11-10 12:07:27 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-10 12:01:29 ARC-1880-VOL#000 Start Checking
2015-11-10 11:07:27 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-10 11:04:29 ARC-1880-VOL#000 Start Checking
2015-11-10 10:34:27 ARC-1880-VOL#000 Stop Checking 001:29:58 0
2015-11-10 09:04:29 ARC-1880-VOL#000 Start Checking
2015-11-10 08:40:27 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-11-10 08:34:29 ARC-1880-VOL#000 Start Checking
2015-11-10 08:25:27 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-10 08:22:29 ARC-1880-VOL#000 Start Checking
2015-11-10 07:31:27 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-10 07:28:29 ARC-1880-VOL#000 Start Checking
2015-11-10 07:04:27 ARC-1880-VOL#000 Stop Checking 008:47:58 0
2015-11-09 22:16:29 ARC-1880-VOL#000 Start Checking
2015-11-09 22:10:27 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-09 22:07:29 ARC-1880-VOL#000 Start Checking
2015-11-09 22:01:27 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-11-09 21:58:29 ARC-1880-VOL#000 Start Checking
2015-11-09 20:07:27 ARC-1880-VOL#000 Stop Checking 000:53:58 0
2015-11-09 19:13:29 ARC-1880-VOL#000 Start Checking
2015-11-02 19:13:06 ARC-1880-VOL#000 Complete Rebuild 023:01:38
2015-11-01 22:20:47 192.168.001.001 HTTP Log In
2015-11-01 20:11:31 ARC-1880-VOL#000 Start Rebuilding
2015-11-01 20:11:25 Enc#2 Slot#4 Device Failed
2015-11-01 20:11:25 RAID6 Rebuild RaidSet
2015-11-01 20:11:25 RAID6 RaidSet Degraded
2015-11-01 20:11:25 ARC-1880-VOL#000 Volume Degraded
2015-11-01 20:06:51 Enc#2 Slot#4 Reading Error
2015-11-01 20:03:44 Enc#2 Slot#4 Reading Error
2015-10-25 23:37:14 ARC-1880-VOL#000 Complete Check 000:59:55 0
2015-10-25 22:37:18 ARC-1880-VOL#000 Start Checking
2015-10-25 22:31:16 ARC-1880-VOL#000 Stop Checking 000:26:58 0
2015-10-25 22:04:18 ARC-1880-VOL#000 Start Checking
2015-10-25 20:37:16 ARC-1880-VOL#000 Stop Checking 002:47:58 0
2015-10-25 17:49:18 ARC-1880-VOL#000 Start Checking
2015-10-25 17:22:17 ARC-1880-VOL#000 Stop Checking 000:50:58 0
2015-10-25 16:31:18 ARC-1880-VOL#000 Start Checking
2015-10-25 16:13:16 ARC-1880-VOL#000 Stop Checking 002:08:58 0
2015-10-25 14:04:19 ARC-1880-VOL#000 Start Checking
2015-10-25 12:46:17 ARC-1880-VOL#000 Stop Checking 000:08:58 0
2015-10-25 12:37:19 ARC-1880-VOL#000 Start Checking
2015-10-25 12:10:17 ARC-1880-VOL#000 Stop Checking 000:08:58 0
2015-10-25 12:01:19 ARC-1880-VOL#000 Start Checking
2015-10-25 10:19:17 ARC-1880-VOL#000 Stop Checking 000:59:58 0
2015-10-25 09:19:19 ARC-1880-VOL#000 Start Checking
2015-10-25 08:19:17 ARC-1880-VOL#000 Stop Checking 000:02:58 0
2015-10-25 08:16:19 ARC-1880-VOL#000 Start Checking
2015-10-25 07:37:17 ARC-1880-VOL#000 Stop Checking 000:20:58 0
2015-10-25 07:16:19 ARC-1880-VOL#000 Start Checking
2015-10-25 07:10:17 ARC-1880-VOL#000 Stop Checking 007:44:58 0
2015-10-24 23:25:19 ARC-1880-VOL#000 Start Checking
2015-10-24 23:19:17 ARC-1880-VOL#000 Stop Checking 000:05:58 0
2015-10-24 23:13:19 ARC-1880-VOL#000 Start Checking
2015-10-24 23:10:17 ARC-1880-VOL#000 Stop Checking 000:32:58 0
2015-10-24 22:37:19 ARC-1880-VOL#000 Start Checking
2015-10-24 21:31:18 ARC-1880-VOL#000 Stop Checking 002:35:58 0
2015-10-24 18:55:19 ARC-1880-VOL#000 Start Checking
2015-10-17 18:52:49 ARC-1880-VOL#000 Complete Check 009:54:26 0
2015-10-17 08:58:23 ARC-1880-VOL#000 Start Checking
2015-10-17 08:10:21 ARC-1880-VOL#000 Stop Checking 007:14:58 0
2015-10-17 00:55:23 ARC-1880-VOL#000 Start Checking
2015-10-17 00:49:21 ARC-1880-VOL#000 Stop Checking 002:35:58 0
