Does anyone know if is there any software that you can use to check SMART errors of each disks in the Areca 1880i?
And also is there any way to benchmark a single drive inside a Raid volume?
Speedfan has the ability to check the individual disks in an array. Has basic check and "extended" check/explanation that takes you to a webpage if you're internet connected.
Loving my 1883ix-24Only big complaint is that as I use this in a workstation environment, the vacuum cleaner noise of the cooling fan is about five different kinds of irritating. Any suggestions on what I can do to mod or replace the fan on this thing?
Good day... does somebody can tell me in short if i can shrink my Raid 6 Array (16x4Tb) on my Areca 1882-24 4Gb by 6 disks, and if how?
space wise i do not need the 6 disks at the moment since it is only about 20Tb full. capacity after removal of 6 Disks would be 32Tb out of 40...
Thanks!
Areca added a firmware level speed test in the latest firmware. Do you get similar results there?
Is the array still building or degraded? What do you mean by "try again"? Did you create a new volume set? A new drive? A new Windows volume? All of the above? Which drives are you using? What's the stripe size?
Still can't get my ARC-1883i working. I've tried in 3 different boards, two different manufacturers. I've tried communicating with Areca support and they've been unhelpful, or I guess as helpful as they choose to be.
The problem is my current ARC-1220 works just fine. Areca's saying that the manufacturer might not allow anything but graphics to be on the PCIe slot. The worst thing is now I'm past my return window.
This is the first "incompatibility" that I've ever had with any hardware combination. Pretty darn frustrating.
For the love of god does anyone have a clue how I'm getting such shit results with my 1882??
I just tried everything again from scratch.
This is 12x 3tb drives in RAID 0!!
Does anyone know If 6TB drives will work on a Areca 1261ML?
I would like to install a few HGST Ultrastar HE6 HUS726060ALA640 drives on it.
They work on the 1231ML, so I would expect them to work on the 1261 as well.
Great! Thanks for that. Then they must work.![]()
