Both work, thought I think I'm the only one here running any of the enterprise 2TB drives. They're just not cost effective for home use.
Well, I've got my Hitachis and I am currently testing them thoroughly. Now I need to order an 1880i. The question I have is does it always come with the 2 fanout cables?
I found an ARC-1880i Here for substantially less than what it is listed for on most other sites. Unfortunately there is no info on whether the fanout cables come with it, and I can see the lower price being a reflection of that. Their support was entirely unhelpful, they essentially emailed me back and said they didn't know...
Anyone here happen to know?![]()
I was needing to get the drives in the 80-89 range to make this a feasible budget. The hitachis are in the 120 range. Even with a volume discount i doubt anyone could hit that price point.
What is this silent corruption issue you spoke of with the Samsungs. Was the issues you experience just due to the expansion i hope.
So samsungs do not work the with the 1880's? I have about 40 drives i am about to order. I need to make damn sure i order the right drives. What 2tb drives aside from the hitachi's actually do work?
I thought the consensus here was the samsungs were okay for the 1880 series.
I need to order these drives asap. But i dont want to be stuck with drives that wont work. Please help me out guys.
I'd say if you are mixing different drives that report different sizes the 10G is your best bet. Granted you lose those little 1-2GB of disk space as it normalizes across all drives.Is there a best practice for Disk Capacity Truncation Mode outside of leaving it at the default 10G?
Anyone have a rough estimate of how long I should expect a Raid 6 to initialize with an 1880i and 8x2TB Hitachi 7K2000s?
********* Change Log For V1.49 Firmware
2010-1-8
1 Improve SMP support for ARC1680
2010-1-27
1 ARC1680/1212/1682 4.9.2.0 transport firmware N.G. for some HDDs
use 4.7.3.0
2010-2-4
1 Fix VOLUME_FAILED cause controller to hang
2010-4-8
1 ARC1880:1st release
2010-4-12
1 Add:HP SAS EXP Card 2.02 support
2010-4-15
1 SAS_HOST_MODE:support 6G expander
ARC1680 ....
ARC1880/8040 ....
2 ARC1880/8040:change STACK_SIZE_LOW to avoid problem when LCD panel or VT100
operate HDD fucntion
3 ARC1880/8040:Add LCD initialization strings (test SDRAM ...)
2010-4-16
1 LCD panel:remove checking of MAX 3 hot spare
2010-4-19
1 CheckMigratingX:added for migration failed but migration status is
inconsistent
2 Remove inconsistent fail flag for raid6 migration
2010-4-29
1 Improve checking of spurious SCB/IO, move the check to LinkErrorDevHandle
2 Fix removing of failed HDD hang the system
2010-4-30
1 ARC1880/8040:Fix LSI6G PLI implementation of Start/StopUnit and SATA
passthrough problem
2010-5-5
1 SUPPORT_CHANGE_CAPACITY:after volume capacity is expanded, return check
condition with CAPACITY DATA Changed
2010-5-7
1 ARC1880/8040:RaidInitZero may break, because raid may be freed before
init routine to complete
2 During volume check of RAID4/5/6, hot removing of entire raidset will cause
raidNumberOfDevices to 0, and checking routine will hang
2010-5-12
1 Fix when expasion raidset and target disk failed, after migration pasued
and controller restarted, the migration halted
2010-5-14
1 Add DISK_WRITE_CACHE_SETTING for models without BBU to control disk write
cache mode
2010-5-17
1 Fix race condition for cache line allocation
2010-5-18
1 Fix SAS/SAS2 model's SPC3 compliance
2010-6-1
1 Add ThreadDelayMs to improve GUI speed of PCI host adapter
2010-6-4
1 Tune ARC1880 performance
2010-6-28
1 Fix ARC1880:1st level attached device's RED LED not on if device removed
2010-6-29
1 Enclosure.c:Add space between E%d and %s
2010-7-2
1 ARC1880:fix zoning problem
2010-7-5
1 ARC1880/1680:Add 6G expander zoning support
2010-7-20
1 Fix TEST_ZONING with log
2 Fix enclousre power off with raidset is initializing or rebuilding...
2010-7-27
1 ARC1880:modify geteon delay stepping,
2010-7-28
1 Add support for mail greet pause, use different tcp_send timeout value
2010-7-29
1 Fix raidset activate problem for rebuilding percentage
2010-7-30
1 Add display of Error Recovery Control Status of SATA hdd
2010-8-19
1 Modify pure SATA's NEW_83782D_HWMON SNMP
2010-8-20
1 Patch ARC1880 bootcode for PLI Phase6/7
2010-8-30
1 Add CheckEesaBlackList to exclude some HDD with error recovery control
problem
2010-9-2
1 Add SUPPORT for ARC1880IXL-8
2010-9-9
1 ARC1880:fix return from BBM with 4G sdram
2010-9-16
1 Fix when many volumes is created for RAID6 and failed two drive, some volume
may still NEED_REBUILD and REBUILDING
2010-9-17
1 Fix SAS devices add/remove routine is invoked before SasDeviceInit is called
2010-10-6
1 Add support for ARC1880LP
2010-10-7
1 Modify GetResource and PostResource
2010-10-15
1 Fix write through problem for IOP348 based HBA
(0) ARC1680/1212/1682/SPT1680/WTN1212
(A) Only ARC1680 reveal the problem
(B) The problme occurred if SUPPORT_PERSISTENT_RESERVE is defined
(C) The problem is the STACK overflow if write through
(D) Change stack size for All IOP348 models
2010-10-20
1 Fix reportlun command to exclude FAILED and FOREGROUND init volume
2010-10-21
1 ARC1680:Add LARGE_DEV_LBA support
2010-10-22
1 SAS2 target mode:ARC8040/8066/8366
2010-10-28
1 Fix MRVL5182 based more than 2TB hdd support
2010-11-3
1 ARC1682:Add over 2TB hdd support
2010-11-5
1 ARC1680:remove VerifyDrive to support seagate SED drive
2010-11-25
1 Add NO_UPS_STATUS for enclosure.c to remove ENC without UPS status
2 Patch supermicro SES problem, unsupported power state report value 6
2010-11-30
1 Add rename raidset name support
2 Port ARC1880 subsystem
4 Add NEW_MAIL_ALERT_CONFIG to support different mail alert config for
different mail account
2010-12-2
0 V1.49 20101202
1 All PCI/E HBA models (except 1880)
2010-12-10
1 V1.49 20101210
2 ARC1880
Looks like official/full HP SAS expander support as well?
Here's a link to the latest v1.49 firmware files for Areca 1280/1680/1880 series cards. As a reminder, you need to upload all four .BIN files contained in the zip file to the card, with the Areca web-based managment GUI, then reboot.
1280: ftp://ftp.areca.com.tw/RaidCards/BIOS_Firmware/ARC1280/149-20101202.zip
1680: ftp://ftp.areca.com.tw/RaidCards/BIOS_Firmware/ARC1680/149-20101202.zip
1880: ftp://ftp.areca.com.tw/RaidCards/BIOS_Firmware/ARC1880/149-20101210.zip
Thanks to the HP expander I sent them to keep on hand as a test unit. I think they basically just confirmed what we already knew "oh look, it works." Even though they market their own Areca branded expander (with a chip OEM'd from LSI), I stressed to them how popular the HP expander has become among Areca owners.
I did have an ulterior motive in sending the test unit, which was for them to address any quirks and compatibility issues quicker, as well as have expander compatibility for new Areca products out of the gate. For example, I think the HP expander negotiates 6G SATA drives down to 3G when attached to an 1880 series card, even with no 3G SATA drives on the chain. Issues like that will hopefully get addressed quicker with a test unit on hand.
do you think that any quirks they did resolve on the HP card would apply to any other expander card that uses the same LSI chip, such as the Astek A33606?
