nitrobass24
[H]ard|DCer of the Month - December 2009
- Apr 7, 2006
Chenbro is technically an LSI expander
I just got my Areca 1880i today.
I'll be testing it hopefully by the end of the week by starting with 4 of the Hitachi 2Tb drives in RAID 6. I'll also test multiple arrays on the controller since I see some people reported issues in this configuration on the Intel based 1680's.
I don't need to expand past 6x2Tb drives in RAID 6 quite yet though, but once I do I'll be adding a SAS expander and Norco 4220 or whatever is out at the time. I'm sure someone will have tested this configuration with the 1880i by then though.
Aren't those two reasons good enough? I call them vital...
no. i'll deal with crap GUI and management if it means a gain in performance.
There is nothing wrong with the LSI hardware, the problem lies within MSM as MegaCli shows the correct info...seriously i still dont understand what the issue was with the lsi card...they are so simple its insane. they have such limited options LOL it is freakishly simple. that is actually a perk of having a bare ass gui and such. maybe a bad card? that is a possibility!
Plus in a windows domain environment, with multiple admins, MSM's authentication works better than Areca's.
On top of that LSI has had more time to mature their firmware than Areca have and have more features than I'm interested in (e.g. the SSD stuff).
Well, here's one that's just about Areca, and got me stumped.
I upgraded a server's 1680ix-24 to v1.48 firmware last night (from v1.46).
First, upgraded the firmware bin. Am told I need to restart system. I do. It comes up ok, then I do the other 3 bins, and the windows drivers. Reboot. Then... nothing.
So today, had to visit the datacenter to sort this out. The Areca firmware wasn't starting up properly, it would then time out, and reboot the server. Ad nauseum.
I tried powering down the server. Same problem. Got into mobo bios, and rebooted. Now Areca firmware would initialize ok, but it couldn't see any drives.
I powered down again, removed all external cables, put them back in, tried again. Still no joy.
Noticed flashing blue light on back of Areca. Hmm, maybe the battery is a problem? Disconnecete battery. Still no joy.
So what worked? I still can't quite believe this, but unplugging the Areca card and then reinserting it worked. System came up! Yay! Rebooted OK. Tried a shutdown. Bad idea. Back to same problem of not seeing drives. Tried removing all power again, including the power supplies, waiting a few minutes, and starting again. No joy. Removed the card and reinserted it again. System came up!
Did this a third time just to check that I wasn't insane.
How can this work? The only thing with any charge in it in the whole server that I can think of is the cmos battery. Surely that doesn't send any power over the PCIe sockets?! How can the Areca card know it's been disconnected and reinserted into a completely powered down system, especially when the bbu has been disconnected?
Well my 1880i's arrived today. I unboxed one and stuffed it in to a Supermicro X8ST3-F and headed home. I've got six Seagate ST3146356SS drives hooked up to it. I'm open to some test scenarios from those who want to know this or that.
...you'll not see much improvement comparing to existing 1680.
To reflash firmware, you have to upload all four files before you do a reboot. If you reboot in between the four files, you mixed up the different firmwares. (the firmware is flashed during bootup)
I recommend you do it again. (with the BBU taken off as well)
Correct, no HP expander.
What bench tool do you want run against the two RAID5's and on what OS?
Is there anyway to use SEAGATE tools with drives connected to an Areca 1880 controller? I have 5 Samsung drives that SEEM to work fine with the controller but I want to test them (SMART, etc) using Seagate Tools but it only sees the card
Thanks Bai. I've tried this, and it was ok for a couple of reboots / shutdowns. Then it stopped working again. Removing BBU, reseating card, even changing slots hasn't helped. I've removed the card from the server to test at home. The rear of the card has a solid green led and a blinking blue led - neither are illuminated on my other 1680ix-24. Solid red led on the BBU even though the Areca UI (BIOS/textmode) reports it as 100% charged. There's also a blinking green led on the card itself, near the expander chip.
Am in touch with Areca support, hopefully they will be able to help me sort this out.
Any more info on this issue? I have this same problem with my brand new Areca 1880ix-24 and a bunch of Samsung disks. Haven't contacted anyone yet, hoping to get it working. If I boot up with 1 drive attached all is fine, then I can add the drives when in Windows and it'll work, just booting screws it up again.
Unfortunately, yes. I had 17 of those drives and 3 Seagates hooked up to a Highpoint RocketRAID 3560 working flawlessly (except for the occassional Seagate dying on me). With the 1880 I have to have 1 drive hooked up while booting to get through the Waiting for F/W screen, then I have to hook up the rest of the drives after Windows has started. Hooking up more than 1 drive reboots the system after 2 or 3 minutes of waiting for F/W and this loops. If I log into the web console I see drives throwing time-outs.
This is not a specific set of drives, it depends on the order they are hooked up in and how many drives are hooked up. Have been fooling around with this since saturday morning, so for about 3 whole days, and by now I'm almost desperate enough to go out and buy WD RE disks
@CollieFjep
Which(model/firmware) Samsung-drives are we talking about?
Is it somehow related to http://hardforum.com/showthread.php?t=1548245?
If it is one of those drives, have you tested that firmware?
I have 5 2TB Samsung F4 disks hooked up to an 1880i on their 24th hour of drive testing and I have not had any issues so far (fingers crossed)
